Sport side skirt removal ?
Anyone know what the damage free removal process is for the side skirts??? I see the bottom bolts and end screws but wonder how you release the top clips or are they simply a pull out clip?? And how many top clips are there???
It depends what you are trying to accomplish. If you're putting on new sideskirt then just pull on them and it should pop off.
Even with the removal tool those clips aren't meant to be reused. You will have to buy new ones anyway.
Read the manual it will tell you which screws to remove then pretty much open your car door then start pulling lightly from the rear of the sideskirt. The clips will pop out.
Aftermarket do not need those clip however OEM requires them but they aren't reusable so you will have to buy new one if you plan to put your OEM back on.
carnacious (06-02-2015)
superjoey
31
03-22-2023 11:56 PM
