Sponsored By:
Sponsored By:
Hit a curb pretty hard help
Old 12-14-2009, 02:06 PM
Sha37
Sha37's Avatar
I hit a curb pretty hard with my front passenger wheel and bended the wheel, I got an alignment and they said everything looks good except for SAI is like .05 degrees off. They said your subframe might have slightly been bent, but the car drives normal and it doesn’t pull. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
The only issue I have now is that when I turn in to go up the driveway or coming off the driveway , on my driver side sometimes something clunks, it was really bad before the alignment, now is still kind of there. (Not as loud though).<o></o>
<o></o>
Also the squeaking annoying noise from the breaks when going reverse, now heard sometimes going forward.<o></o>
<o></o>
Any ideas?<o></o>
Old 12-14-2009, 02:19 PM
WhosUrBuddiee
WhosUrBuddiee's Avatar
No one on here can diagonose your car via internet. Take it to a dealer or mechanic and have them check it out.
Old 12-14-2009, 02:41 PM
hispeed-lowdrag
hispeed-lowdrag's Avatar
^+1
the only thing to do after something like that is to have a licensed mechanic look at it either at the dealership or somewhere you trust
Old 12-14-2009, 03:19 PM
nogoodname
nogoodname's Avatar
Alignment should be the last thing to do. Most likely you bent or brok
Old 12-14-2009, 06:59 PM
Sha37
Sha37's Avatar
I just wanted to get some ideas on what I am up for. maybe some people had similar issue either with g37 or g35 as alot of people on here owned before. (worst case scenario) every car has its weak points in a typical pothole, curb or etc accident.
mechanic already checked it, I had to get an appt to take it back in for them to put it on the frame machine.
Old 12-14-2009, 07:40 PM
dpadman
dpadman's Avatar
First time ever hearing of a bended wheel. I would be scared if I bended anything. I wouldn't try to drive on the bended wheel. You think the dealer could bended it back?
Old 12-14-2009, 07:46 PM
Xcalibur
Xcalibur's Avatar
Originally Posted by Sha37
I hit a curb pretty hard with my front passenger wheel and bended the wheel, I got an alignment and they said everything looks good except for SAI is like .05 degrees off. They said your subframe might have slightly been bent, but the car drives normal and it doesn’t pull. fficeffice" /><o>></o>>
<o>></o>>
The only issue I have now is that when I turn in to go up the driveway or coming off the driveway , on my driver side sometimes something clunks, it was really bad before the alignment, now is still kind of there. (Not as loud though).<o>></o>>
<o>></o>>
Also the squeaking annoying noise from the breaks when going reverse, now heard sometimes going forward.<o>></o>>
<o>></o>>
Any ideas?<o>></o>>
Dude that's what insurance is for. It sounds to me like $600-$800 dollars worth of damage not to mention labor cost as well.
Old 12-14-2009, 08:04 PM
nogoodname
nogoodname's Avatar
you could fix the bent rim at a wheel shop.... it does make the wheel weak afterward i heard... and cannot fix it a second time... one time thing
Old 12-15-2009, 05:01 PM
Sha37
Sha37's Avatar
my deductable is $500, so if anything below $1000 I just pay out of pocket. as far as the wheel, I am getting some vossens 82s. it was meant to be. I just wish I pulled the stupid move a little later to wait and see how the vossen concaves look like on our cars.
Old 12-15-2009, 05:28 PM
chasemyaccord
chasemyaccord's Avatar
Yeah I'd get that double checked by a certified mechanic first. How exactly did you hit a curb so hard as to bend your rim?
Old 12-15-2009, 06:10 PM
nogoodname
nogoodname's Avatar
if pot holes can dent a rim, i'm sure a curb will dent it good
Old 12-16-2009, 01:19 PM
DetroitG37Joe
DetroitG37Joe's Avatar
I hope you didnt bended anything moer expensiver than your rims!!!
Old 12-16-2009, 01:30 PM
Sha37
Sha37's Avatar
will see, I hit it pretty hard, I would say around 25 MPH. I blew up my tire and went over the curb to the other side actually. The body shop near by got a opening on their frame machine tomorrow, I just got bunch of stuff thrown at me at work hopefully I would make it. I am not too worried since the car doesnt pull on either acceleration or breaking.
Old 12-18-2009, 03:52 PM
Mayu
Mayu's Avatar
Ouch!
Old 12-18-2009, 04:21 PM
nogoodname
nogoodname's Avatar
ouch... went right over the curb??... how's the side skirts??.... also, right after the hit/accident.. was the steering a bit messed up.. like the steering wheel is a bit crooked to drive straight??
Quick Reply: Hit a curb pretty hard help
