Sponsored By:
Sponsored By:
intelligent key question
Old 10-27-2009, 12:58 AM
terrycs
terrycs's Avatar
Originally Posted by drjspecv
I guess I'll be making the trip in this Thursday. I well let everyone know the outcome because once again the light was on leaving from work.
Do you have the same problem with BOTH ikeys or just one? Both ikeys most likely means a problem with the car.
Also keep in mind, the more often the ikey buttons are used, the faster the battery goes dead.
Old 10-27-2009, 08:58 AM
2008G-Man
2008G-Man's Avatar
Originally Posted by Mike P
I have not had any issues with mine. I have not needed to change them. I barely use it. I use the tab on the door to open the doors most of the time. Glad to know there's a DIY on this.
Doesn't matter how you open the door, the car reads the signal/battery strength once inside. If you are not getting the indicator, your battery is still OK. That is a very common battery size so you can get one just about anywhere that sells batteries.
Old 10-27-2009, 11:22 AM
terrycs
terrycs's Avatar
I think he's trying to say battery life in the ikey is longer becasue he "barely uses" the ikey's buttons. The transmitter in the ikey uses more battery power than the RFID by itself.
Raleclair
10-08-2015 02:06 PM
Amaadkhan2k
09-12-2015 08:10 PM
rgonz
09-11-2015 04:07 PM
Detailed Image
Lighting/Cleaning Products
09-11-2015 08:33 AM
Quick Reply: intelligent key question
