Problem with G37s?
Problem with G37s?
I just picked up my 09' G37s last week. I had to buy it from a dealership about 200 miles away. The car drove awesome the entire way home. Soon after I got off of the freeway and on to a normal road, as I was shifting I noticed the service engine soon light came on. The car sounded funny, like it was missing and as I would give some gas, say something over 3,500 rpm, the car would stall out. The engine would not cut out it would just not go. I had to milk the rest of the way home, about 2 miles.
The car has not done it since and has been running great, I don't see a point of going to the dealer, I am sure they will say "no problem found".
Just curious if anyone has experienced anything like this?
My 08 G37S has done that a few times, but not in the same situation. Mine has been when its parked, I will start it, put it in reverse to get out of my garage or parking spot and when I give it gas, it hesitates, like its not getting gas. I have tried gassing it hard, to get it to kill, so it will throw a code in the computer, but no luck. When I gas it hard, it will work the "burp" out of its system and work normally. This has happened to me probably 6-7 times, and there is no rhyme or reason as to why it does it. I have talked to the dealership about it and they have no idea as to what is causing it, and they claim they have never heard of it happening before. I'm at a loss also, and not so happy that it is doing it.
(I have been running Shell V-Power in the car ever since I purchased it, so its the proper octane fuel.)
https://www.myg37.com/forums/g37-sed...ler-twice.html
limp mode happen to me too. rpm wouldnt do more than 2000. i was teaching my wife how to drive stick before that. i thought it was her fault. i gave it a rest for 15 mins and then all back to normal after that. never happened again.
My car is at the dealership right now for a window fix and it acted up for them. They told me that they hooked some equipment up to it and found out that it was losing fuel pressure, so they are ordering fuel injectors for it. I would have thought that a loss in fuel pressure would be a fuel pump issue, but what do I know? Hopefully it fixes my issue.
Chris Olson
03-28-2024 09:46 AM
maybeg37
09-08-2015 02:33 PM
