Dealership = FAIL!!!! :(
#31
I raised a stink about mine making too much noise. Then I found that almost all of the 6MT's (and thats G35 and 350Z/370Z) make this noise. The exception may be PMS. She took hers in and they replaced a lot of her tranny parts which made the noise go away. You may want to PM her.
#32
A note is if you went w/ an aftermarket clutch it does get rid of the throwout bearing chatter.
#34
Car is fine.. Normal.. Noise is present when tranny gets hot from harder driving conditions. However on a cold start and normal driving temps the noise is not always present and disappears when clutch pedal is pressed.
Victory
17
10-27-2022 03:45 PM
nbast
09-14-2015 12:39 PM
