Sponsored By:
Sponsored By:
Fuel Capacity
Old 03-19-2009, 08:20 AM
levin91e
levin91e's Avatar
Fuel Capacity
Hey everyone. How much fuel does your G37 coupe take when you fill up if your on E and the range meter is showing dashes and flashing?
The manual says the tank is 20 gallons. I know most cars have about 1 or 2 unuseable gallons. So I should expect to put in 18 or at least 17 gallons.
Mine only takes 14.75 gallons when on E and range meter showing dashes WTF? I read somewhere that there is a TSB on this but I wanted to see what everyone else was getting first before bringing it in to the dealer.
Old 03-19-2009, 09:48 AM
w0ady
w0ady's Avatar
depends how you drive and what your average miles per gallon is. i usually end up putting in anywhere from 14-17 gallons when i get down to the warning.
Old 03-19-2009, 10:02 AM
aliiin
BMW Defector
aliiin's Avatar
i think the tank is 20 gallons but the reserve is like 2-3 or something like that
Old 03-19-2009, 10:07 AM
04STi208G37
04STi208G37's Avatar
Variable
+1 ^ The range meter seems variable (depending on how you drive) and very , very conservative. Example. It says I have 40 miles. I start driving harder, using DS and paddles. Suddenly it says I have 30 and flashes. If I back off, it still keeps saying 30. If I keep driving hard, it goes to dashes in no time flat. I might still have 3 gallons. It seems to think I might get less than 10 miles per gallon.
Old 03-19-2009, 10:22 AM
Modme
Modme's Avatar
^I think you need to reread the original post.
Old 03-19-2009, 10:34 AM
scorviss
scorviss's Avatar
I tanked up on E the other day and filled up 18.2, usually it's right around 17.5-18.5, hope this helps!
Old 03-19-2009, 11:28 AM
GeeeeOhhhh
GeeeeOhhhh's Avatar
when i'm at E and my distance to empty shows ***** i fill up about 17.3 gallons.
Old 03-19-2009, 11:36 AM
Roseyhebert
Roseyhebert's Avatar
I'm with everyone else on this. Usually about 17.3-17.5.
Old 03-19-2009, 11:56 AM
Heat
Heat's Avatar
I have actually hit the dashes before and thought I was going to run out of gas cause I was stuck in a traffic jam. When I finally made it to the gas station, I only filled up to 18 gallons. I was like wtf? But I normally fill up when I hit the 50 miles left and it only takes 16.
Old 03-19-2009, 12:38 PM
ucla bruin
ucla bruin's Avatar
I've gone to about 20miles left on the range, normal driving condition, and tanked up only 15gal. I don't seem to go over 16gal when I fill up anymore. It's kind of odd.
Gan78mao had a similar problem and got a sensor replaced at the dealership.
__________________
Old 03-19-2009, 05:19 PM
dimapassionz
dimapassionz's Avatar
i dunno if this helps but on my fx35 it would show dashes and on E and i started panicking. I would start the car again and start driving conservatively and it would say 35-45 miles left. also, i had an issue where my tank wouldnt fill up past 3/4, so depending on the severity of your problem, i would seek advice
Old 03-19-2009, 10:38 PM
chasemyaccord
chasemyaccord's Avatar
I think the most I've filled was 17.5ish. It's depressing since that's more than my Accord's total capacity, and I get roughly the same miles out of the tank except the G takes premium. Boo hoo...
But at least gas is still relatively cheap. Yay for rising oil supply!
Old 03-20-2009, 03:08 AM
xyz
xyz's Avatar
The light usually light up at around 40 miles left, which is about 2 gallon for me. Then I can drive another 40 miles after it reaches 0. So it about 16 gallon right when it lights up. I usually get it when it stop displaying mileage left, which is around 18 gallons.
Old 03-20-2009, 11:29 AM
InfinitiFreak
InfinitiFreak's Avatar
When I fill up on E, I can usually put about 17.5 gallons in.
Old 03-20-2009, 12:11 PM
Heat
Heat's Avatar
I always try to fill up at around 50 miles because I never wanted to get the junk in the bottom of the tank. After reading all this crap and how there is an extra 2-4 gallons left, I am taking that biotch all the way down to -- now.
Quick Reply: Fuel Capacity
