Washi door grip install Help
Just picked up my new washi door grip from my local dealer and am ready to install. Only problem is I'm not sure how to go bout it. I thought there was a full DIY on here but all I found was this https://www.myg37.com/forums/body-in...r-pulls-2.html
Is there anything that goes into more detail or can someone post up more info?
Thanks
Thanks
im pretty sure you just pop em off n on...if u stick a flat head screw driver or a butter knife in the little opening on the lower front edge u should be able to hear it pop out of place..then do the rest with your fingers...where did u get them from and how much..im looking to get these too
