VDC question
VDC question
So it was wet the other day and I figured I'd do a little fishtail. So I turned off the VDC (I never really do this), gave it a little gas and the car begins to fishtail but then the slip light came on. So I stopped giving it gas and continued home.
My question is if I turned off the VDC why would the light flicker. Is it just letting my knwo that I am slipping or is there some other traction control I am unaware of?
Understand I don't really horse around with my car so I've never really worried too much about actually how to use the VDC button.
From Owners Manual
When accelerating or driving on slippery surfaces, the tires may spin or slide. With the Vehicle Dynamic Control (VDC) system, sensors detect these movements and control the braking and engine output to help improve vehicle stability.
When the VDC system is operating, the SLIP indicator in the instrument panel blinks.
If the SLIP indicator blinks, the road conditions are slippery. Be sure to adjust your speed and driving to these conditions. Be sure to drive carefully. (See Slip indicator light in the 2. Instruments and controls section, and Vehicle Dynamic Control (VDC) off indicator light in the 2. Instruments and controls section.)
Indicator light - If a malfunction occurs in the system, the SLIP and VDC OFF indicator lights illuminate in the instrument panel. As long as these indicators are illuminated, the VDC system function is canceled.
The VDC system uses an Active Brake Limited Slip (ABLS) function to improve vehicle traction. The ABLS system works when one of the driving wheels is spinning on a slippery surface. The ABLS system brakes the spinning wheel, which distributes the driving power to the other drive wheel. If the vehicle is operated with the VDC OFF switch pushed and the VDC system turned off, all VDC systems will be turned off. The ABLS system and ABS will still operate with the VDC system off. If the ABLS system is activated, the SLIP indicator will blink and you may hear a clunk noise and/or feel a pulsation in the brake pedal. This is normal and is not an indication of a malfunction.
While the VDC system is operating, you may feel a pulsation in the brake pedal and hear a noise or feel a vibration from under the hood. This is normal and indicates that the VDC system is working properly.
The VDC system computer has a built-in diagnostic feature that tests the system each time you start the engine and move the vehicle at a low speed forward or backward. When the self-test occurs, you may hear a ªclunkº noise and/or feel a pulsation in the brake pedal. This is normal and is not an indication of a malfunction.
I dont see in there were it talks about how it functions with the VDC off.
From Owners Manual
from owners manual
when accelerating or driving on slippery surfaces, the tires may spin or slide. With the vehicle dynamic control (vdc) system, sensors detect these movements and control the braking and engine output to help improve vehicle stability.
When the vdc system is operating, the slip indicator in the instrument panel blinks.
If the slip indicator blinks, the road conditions are slippery. Be sure to adjust your speed and driving to these conditions. Be sure to drive carefully. (see slip indicator light in the 2. Instruments and controls section, and vehicle dynamic control (vdc) off indicator light in the 2. Instruments and controls section.)
indicator light - if a malfunction occurs in the system, the slip and vdc off indicator lights illuminate in the instrument panel. As long as these indicators are illuminated, the vdc system function is canceled.
The vdc system uses an active brake limited slip (abls) function to improve vehicle traction. The abls system works when one of the driving wheels is spinning on a slippery surface. The abls system brakes the spinning wheel, which distributes the driving power to the other drive wheel. if the vehicle is operated with the vdc off switch pushed and the vdc system turned off, all vdc systems will be turned off. The abls system and abs will still operate with the vdc system off. If the abls system is activated, the slip indicator will blink and you may hear a clunk noise and/or feel a pulsation in the brake pedal. This is normal and is not an indication of a malfunction.
while the vdc system is operating, you may feel a pulsation in the brake pedal and hear a noise or feel a vibration from under the hood. This is normal and indicates that the vdc system is working properly.
The vdc system computer has a built-in diagnostic feature that tests the system each time you start the engine and move the vehicle at a low speed forward or backward. When the self-test occurs, you may hear a ªclunkº noise and/or feel a pulsation in the brake pedal. This is normal and is not an indication of a malfunction.
Here is some better stuff in the owners manual. At least humor wise.
WARNING
The VDC system is designed to help improve
driving stability but does not prevent accidents
due to abrupt steering operation at
high speeds or due to careless or dangerous
driving techniques. Reduce vehicle speed
and be especially careful when driving and
cornering on slippery surfaces and always
drive carefully.
drive carefully.
If engine related parts such as muffler are
not standard equipment or are extremely deteriorated,
the ªVDC OFFº indicator or ªSLIPº
indicator or both indicator lights may
illuminate.
illuminate.
Do not modify the vehicle's suspension. If
suspension parts such as shock absorbers,
struts, springs, stabilizer bars and bushings
are not INFINITI approved or are extremely
deteriorated the VDC system may not operate
properly. This could adversely affect vehicle
handling performance, and the ªVDC
OFFº indicator or ªSLIPº indicator or both
indicator lights may illuminate.
If brake related parts such as brake pads,
rotors and calipers are not standard equipment
or are extremely deteriorated, the
ªVDC OFFº indicator or ªSLIPº indicator or
both indicator lights may illuminate.
I dont see any clarity here regarding the VDC. I have pushed and held the VDC in and the VDC light comes on and stays on. Once the light is on at this point I can not get it to go out. Its like it is stuck on. It takes for me to shut off the car then restart to clear the light. Referencing the manual language, our system is not fully defeatable and that, my friends, sucks!
