VDC question
The VDC system uses an Active Brake Limited Slip (ABLS) function to improve vehicle traction. The ABLS system works when one of the driving wheels is spinning on a slippery surface. The ABLS system brakes the spinning wheel, which distributes the driving power to the other drive wheel. If the vehicle is operated with the VDC OFF switch pushed and the VDC system turned off, all VDC systems will be turned off. The ABLS system and ABS will still operate with the VDC system off. If the ABLS system is activated, the SLIP indicator will blink and you may hear a clunk noise and/or feel a pulsation in the brake pedal. This is normal and is not an indication of a malfunction.
That is really confusing me. So the car has a VLSD (viscous limited slip differential) and also uses ABLS (Active Brake Limited Slip)?
And ABLS is still active with the VDC off? That sucks!!!
Somebody tell me I'm all messed up.
I get this too, I was wondering what was going on. I guess it's just the ABLS thing kicking in.
I noticed it during my autocross last weekend. Wheels spinning and I'd see the slip light blink a little. Good to know it's not still trying to stop me from sliding around.
(not that it was effective): http://www.youtube.com/watch?v=R7Jk8ZmVAkE&fmt=18
Your absolutely correct. I do get slip light on tight corner when I slip but when both wheel were slipping, slip light did not blink.
+1... If I push it hard it will flicker, but does nothing to the car; did the same in my G35 before this G
#30
when u turn off vdc THERE is still traction holding the car back why wont some1 then turn off vdc and try to do a burn out it wont let u im not sure about the 6mt the automatic it wont let u cuz something is still holding the car back the car burns out for about 3 sec's and stops cuz of traction even wen vdc is off
