G37S Front Bumper Square Opening??
#31
It is a good package but it just not too useful compare with the other packages that G37 has,i would love to have it if it comes with the car for standard optional. I am just talking about my feeling of this package, i did not say INFINITI should not make cuz i think it is useless.
G is the best
G is the best
#32
G is the best
G is the best
We "Drive" not "Commute"...
#34
#36
#37
totally different! how much you have paid for 330hp? and how much you have paid for you tech package? 330hp comes with the car! Tech package is an optional, anyways, that was just my opinion.
#38
Well what I did, I ordered the front Grill Non tech package without the whole, replaced and it looks way better, the funny thing is that ACC would not work if anything is on the way of its laser, but i tryied it a few times on the highway and it works fine. but then i again i dont really travel much so i dont use it.
#40
![Biggthumpup](https://www.myg37.com/forums/images/smilies/biggthumpup.gif)
#41
There is an "I" bolt in the trunk with a loop on the end for a tow truck to fasten to if you are stuck in the mud etc. This square pops out and the bolt is screwed into the fitting. - instruction book! Its with the lug wrench.
#42
Not problem I will keep you guys posted, the only problem i have found so far that took me a while is that i could not set the the distance or the speed the display would just start blinking. anyways i found out that i had my VDC off and it wont let you use the ICC. Couple of things i've done so far:
1.) got on the highway, turned on my VDC annd set my speed.
2.) I set the distance( tried them all) works fine
3.) got behind a car and started desaccelarating how it should.
So Far so good but i have not tested it long enough to see how sensative would be with the grill on. I will take pic of my car so you guys could see how better it looks. I will keep you Posted!!
#44
Especially when the sensor gets dirty and needs to be cleaned- it would be a huge pain to take that grille off each time that sensor needed to be cleaned. I'll deal with the opening in my front bumper- nobody can really see it anyways.
#45
Nobody is talking about covering it with a solid plastic bumper, we're talking about the full lower mesh grille. Apparently it does work as dnieto82 just posted that be did it and it's working. It would be easy to clean, just spray some type if APC or degreaser on the sensor face through the mesh, use a thin long handled brush to brush it, and spray water in there with a hose to rinse it off. If it gets really grimy, it takes about 5 or 10 minutes to pull the bumper off to clean it.
How much is the part (lower grille)?
