Public Service Announcement
Old 01-15-2009 | 05:42 PM
mpbruin108's Avatar
mpbruin108
Just letting you guys know that their is a ECM (ECU) programming recall. Yesterday I took my G to get it's oil change and to complain about a ticking sound from my engine. When I got the car back, they told me the ticking was caused by something with the ECM. They told me they reprogrammed the ECU (which wiped out my reflash data) to make the ticking go away. It was part of a campaign recall.
So....if you guys have flashed ECU's (something other than Cobb Accessport), then be wary that you guys have to redo the flash. Otherwise, go get your updated ecu bug fix from Infiniti!
Old 01-15-2009 | 05:43 PM
Blackjack's Avatar
Blackjack
Is there a TSB?
Old 01-15-2009 | 05:46 PM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
Which dealership did you go to ?
Old 01-15-2009 | 06:39 PM
mpbruin108's Avatar
mpbruin108
Millers Infiniti in van nuys, california
Old 01-15-2009 | 06:40 PM
mpbruin108's Avatar
mpbruin108
Originally Posted by Blackjack
Is there a TSB?
whats a tsb?
Old 01-15-2009 | 06:41 PM
sTiLLBaLLiN37
Which service rep did you work with? Randy?
Old 01-15-2009 | 06:43 PM
Graham's Avatar
Graham
Is this the Ester Oil or VVEL TSB? Reflash your ECU and switch to Ester Oil? Sounds like what your talking about.
Old 01-15-2009 | 07:54 PM
ucla bruin's Avatar
ucla bruin
Are you sure it's a recall? If so is there a TSB, technical service bulletin?
Do you have the papers from the dealers?
__________________
Old 01-15-2009 | 08:00 PM
shumby's Avatar
shumby
https://www.myg37.com/forums/tsb-tec...-9-3-08-a.html
I think this is what he had done.
Old 01-15-2009 | 08:09 PM
da mayor's Avatar
da mayor
taht ticking noise TSB has been out... yup thats the same thing
Old 01-15-2009 | 08:58 PM
Callaway's Avatar
Callaway
Arm flailing tube man
had mine fixed under that tsb.
Old 01-15-2009 | 09:42 PM
The1andOnly's Avatar
The1andOnly
Funny thing, I had the VVEL knocking also , but it stopped after I installed the Cobb AP.
Old 01-15-2009 | 10:18 PM
machinist's Avatar
machinist
Does this TSB apply to the '09 G37x as well?
Old 01-15-2009 | 11:59 PM
mpbruin108's Avatar
mpbruin108
Jeff Flanagan....good man! Maybe it was the ester oil thing...I'm not sure. All he told me was what I told you guys...either way, doesn't hurt to check just in case at your next oil change.
Old 01-16-2009 | 08:13 AM
Callaway's Avatar
Callaway
no. if they didn't fix it for the 09, than Infiniti is stupid.
Quick Reply: Public Service Announcement
