My first mod!!!
My first mod!!!
I know it's not much, but it's officially my first mod with many to follow.
This of course was with the help of my boyfriend. He made me do all the work and hold the light. It was hard to get the new cover piece to click in. He came up with a nifty little trick to make it work.
She did everything except get the clip all the way on. Then after about 15 minutes of failing myself, I had to regroup. Our problem was the plastic parts of the door handle were flexing too much inside. I tried getting the door panel off but I didn't have the right tool (I do now). So, I did a little more looking and found a hole in the side of the door covered with a rubber plug. I got a screwdriver, taped it up, and used it as leverage as we pushed on the new keyhole cover. Worked like a champ on the first try.
I wanna get this mod and I'd have it done by a pro, but I just wouldn't want them to mess it up. I guess for them, it's a no brainer to remove and put on, right? I mean from what I've heard, the only real downside to this mod is if you run outta batteries in your key remote, right?
chicks working on cars is hot...i agree....and there's plenty of them actually...trouble is...you'll get into arguements with them all the time cause you'll know one thing about cars, and the stubborn other will always argue otherwise....
Her ... you car is bright! My eys are still seeing red!
