TCS And VDC???
To the left of the sterring wheel and around the knee area are a cluster of buttons. The furthest to the left marked VDC; push it and a "VDC OFF" light will pop up on you gauage cluster.
This does not turn the VDC off, rather it reduces its intervention to almost non-existent (so I've read in reviews).
Push the button again to turn off the warning light and turn VDC back on.
Both according to http://www.infiniti.com/g_coupe/spec...ons/index.html
Vehicle Dynamic Control (VDC)
A change in traction can affect your car's stability during cornering. VDC[1] uses an array of sensors to help determine your steered path and to help keep you in control. If your vehicle begins to understeer (plow forward) or oversteer (fishtail), VDC applies appropriate brake pressure to individual wheels and/or reduces engine output to help keep both ends in line.
Traction Control System (TCS)
G37 Coupe's integrated Traction Control System (TCS) senses wheelspin while accelerating and automatically reduces engine output and/or brakes the spinning wheel to help regain traction.
