Buzzing/Rattle - anyone else have this?
I have this rattle/buzzing sound coming from either the dash or right door. It does it over bumps, under hard acceeration, and at higher RPMS (constant RPM). I have searched the boards and do not see anything that sounds like this.
It is really starting to **** me off to the point where I want to drive it into a wall and leave it, or trade it in......
So, if anyone knows what this might be, please let me know so the dealer can address it.
FYI - This does NOT sound like the tapping nosie from the heater core.....
I've got some as well. Not sure if anyone has notice these. You may have to REALLY REALLY listen CLOSELY. And these sounds with the exception of the last one...only happen sometimes. Actually wished it was constant so I can take it to the dealer. BTW, my car has 9400 miles and has a build date of Aug 07
1. Speaker Passenger Side - sounds like it's the speaker but can't confirm
2. Sunglasses Holder (no sunglasses in it) - rattles slightly on certain rough roads like a freeway interchange
3. Ashtray - noticed sound coming from ashtray...when I opened it, sure enough it was louder. Pushed the ashtray and made it stop...but then again...pushed on the washi paper trim around the ashtray and that made it stop too...not sure how to fix this one.
4. Rear passenger side - this one is weird. This one is sort of consistent in that you hear a slight crackle or pop regardless of the whether the road is smooth or rough. However, the time between the sounds is inconsistent. But usually anywhere from 5-15 seconds. They only way to describe it is like when your dashboard cracks or pops when its adjusting to the temperature like when you turn on your ac on a hot day. Definitely noticeable.
OK, I know this is a ridiculous answer...
I had a rattle/vibration coming from somewhere in the car. I couldn't figure out where it was coming from. Turns out it was a bottle of water in the cup holder in my driver's door. For some reason it souded like it was coming from the rear though. Very strange.
Anyway.... good luck
Yep, I got that, I don't like it but I'm learning to live with it. I think its inside too, but make sure you try everything people have said and turn off the radio, empty the glove boxes, sunglasses holder, ..EVERYTHING, drop the passenger seat belt etc to make sure. Once mine go worse and I thought it was coming from the passenger side and it turned out just to be sunglasses, very hard to track these noises.
Buzzing/Rattle
I just bought a 6mt and I have this weird buzzing noise from the front left side of the engine, everytime I push the clutch in the noise goes away. Any ideas on what that could be?
It's your clutch, the noise exists for almost all models. Unless the noise gets progressively worse, there's nothing to worry about. Dealerships will tell you it's just a characteristics of the G. Search for threads on this, PM me if you can't find any.
__________________
__________________
i had one that sounded like it was coming from the dash...it's the airbag. If I put my hand on the airbag/horn it stops...took me a month to figure it out and just haven't had time to get it into the dealer yet.
