My G37 is one year old today and whereas I’ve read never to buy a new model in its first year I can honestly say there’s been no recalls, no nagging design flaws and no real problems except for one thing:
Twice now, on different tires, when I’ve added some air (like some politician says will eliminate or dependence on foreign oil) the valve stem core has failed as I finished with air rushing out only stopped by the valve cap and a trip to the dealer to replace the valve under warranty. Is my motor driven pump somehow causing it or are our valves prone to such things?
2004-2008 ALL INFINITI MODELS; TPMS SENSOR SEAL LEAK
When repairing an air leak at a TPMS (Tire Pressure Monitor System) sensor seal, a seal is now available
separately.
separately.
Thanks for the tip, but it doesn't appear to be a TPMS problem, and I found no TSB’s for the difficulty I described. Before I go out and buy a new air compressor, I’m wondering if anyone else has had this problem.
