Sponsored By:
Sponsored By:
Sour Smell
Old 08-25-2008, 02:54 AM
Comatose
Comatose's Avatar
.. and i always thought running AC was good to removing condensation.. ??? hence its use for defogging your windows etc.
Old 08-25-2008, 08:09 AM
hershy67
hershy67's Avatar
i get the smell of old gym socks every now and then even when i do not use the AC.
Old 08-25-2008, 08:23 AM
fcarpio
fcarpio's Avatar
Do you blast the A/C every time you use it? Maybe you should increase the temp a bit.
Old 08-25-2008, 09:20 PM
DrJones
DrJones's Avatar
Guilty! I do keep it on recirculate as to avoid the exhaust smells from other vehicles coming in the cabin. I am definitely going to heed the advice to eliminate the odor. BTW, Infiniti said my in-cabin filter was perfectly fine and didn't need to be changed and the wife doesn't have any problems with my ***** (good one Jeremy!!).
Old 08-25-2008, 11:06 PM
chain492
chain492's Avatar
is this the smell that you get when you turn on the temp to low without ac? or when the ac is not warmed up?
mine smells like mild mildew, but it goes right away after the ac turns on, im assuming you live in a humid place, in korea in the summer the ac doesnt smell so fresh, but its really cold.
Old 08-26-2008, 01:17 AM
silent06
silent06's Avatar
Originally Posted by conmanx420
Do you keep it on "Recirculation" mode most of the time? That usually causes a "stale/mildew" smell.
Plus the manual says not to keep in on this mode for extended periods of time because of this very reason.
If that's the case just put it to fresh air mode to flush out the stale air and you should be fine.
+1 This was posted on Driver or Fresh Alloy back when the G debuted. I have always keep mine on Auto/Fresh Air and have never had the stale or mildew smell in either of my previous G35s.
Old 08-26-2008, 10:22 PM
teedough
teedough's Avatar
either something died inside or something took a **** or ****
Old 08-27-2008, 12:09 AM
beestea
beestea's Avatar
I am having this problem as well.... When I first bought the car it had a slight musky smell when using the AC but that went away after a few months. This summer the past month + everytime I fire up the car with the AC on I get a nice big blast of mildew smell but it goes away after about 10 seconds. Really strange.
My last car had this problem after like 4-5 years which I just delt with... but it sucks that im already getting the mildew smell on the G37 after only 11 months.
Victory
17
10-27-2022 03:45 PM
claudiohv
09-17-2015 01:43 AM
sdpaulie
Southern California
108
05-27-2009 05:30 PM
Quick Reply: Sour Smell
