why cant i do a burnout??? and wth is icy???
#76
yup ive seen 500rwhp+ g/z's unable to do a burnout in 1 spot with pulling the fuse. and im sure sharif has seen even more. i understand it may be confusing between spinning your tires while launching and doing an actual burnout. however, a burnout is what you cars with slicks doing in a water box at the track or a burnout competition. we have too many electronics to allow it stock sorry.
#77
i can do a burnout in my moms RDX HHAHA. but how much times we gotta do dis, press da breaks and gas at da same time and treat it how u would treat a clutch and a gas pedal. even em out and bada bing bada boo. o yea and vdc off
#78
![](/images/premier.gif)
#80
just found out how to do one today..under drive kickpanel fuse box take out fuse that says stop lamp and in the pass side of hood by batter look in the big fuse box located behind the battery under the fender and pull out fuse that says abs.. this will let you do a stand still burnout but put fuses back in after this is only for track use
#81
Wow I didn't realize how old this thread was..........................For me I just nail the gas and I do a burn out, can do them in both cars with just turning off the VDC. I posted pictures of one I did in a parking lot one night somewhere a while back.
