Computer problems?
Computer problems?
The tinter did some work on my windows and disconnected my battery while he worked. Now my auto headlights don't work. They go on but don't turn off. The passenger window doesn't work either (this happened last time and I will reset it when the tint dries.)
The lights are a new issue. Anyone know if I need to reset something? Does anyone know how?
Thanks for your help.
Check your settings for the Auto Headlight's, adjust them to turn off after 10secs and see if that works. Also make sure the passenger window lock button is not engaged or the window will not work, its on the drivers door.
If you can't fix it I suggest unplugging the car again for 10-15 minutes. Why the heck did he disconnect your battery in the first place??
lol...The window issue was just because the window lock was down. Boy, I feel smart now.
I changed the auto lights timer in settings but that didn't work. I will try to disconnect the battery today.
I just assumed he disconnected to avoid it moving during the process or to not run the battery down. Now that I think about it, not sure that makes sense.
butwhatuptho
10-04-2015 07:51 PM
Msherburneg37xs
Intake and Exhaust
09-30-2015 06:39 PM
FlyIce
09-29-2015 04:07 AM
