im sure plenty of you guys have had your 3,500 mile service im just trying to get a ballpark idea of what the dealer charged you for the service before i take mine in. i went from a toyota tundra which was always around $40-60 for service. thanks
I'm taking mine in today actually. I think the only thing you do is an oil change ($39). Tire rotation isn't until 7,500 which is $29 or $39 w/balancing. So basically all you're doing is an oil change. I'm going to balance and rotate my tires though, trying to get the most out of the stockers.
Yeh rotate side to side, they are not directional tires especially since the sizes are do not match. I'm just getting my oil changed, tires are wearing in fine so I'm going to wait another ~1500 to balance/rotate em.
If you have the S model you can rotate them side to side, but NOT back to front.
rotating them side to side will do nothing for you. you are not changing the contact patch at all. its a waste of time. Unless you are removing the tires themself and switching them from rim to rim. but you cant do that with the re50's as they have an outside and inside...
