View Poll Results: What did YOU choose?
6MT
140
53.64%
5AT
121
46.36%
Voters: 261. You may not vote on this poll
6MT or 5AT
Old 09-13-2007 | 07:10 PM
  #166
ABQG35c's Avatar
ABQG35c
I give a crap.. If you don't, then don't post in this thread.. It's that simple.Thank you.
Old 09-13-2007 | 07:19 PM
  #167
kg37's Avatar
kg37
Originally Posted by mal_TX
Torque multiplication does not occur when the torque converter is locked up. The torque converter will lock up at about 3k when it stalls, or about 4k via ECU command. After it is locked up, it is similar to an engaged clutch. There is no torque multiplication in higher gears unless your torque converter is not locked, which means you will be losing power overall. Prove otherwise and I'll thank you for teaching me how a torque converter works.
The clutch drop from a dig is not that much better than the high stall converter. They are both designed to get the engine RPMs high before engaging the drive wheels. Both are valid approaches. The AT's torque multiplication will help cancel out the MT launch. I agree that a hard core launch on the MT is beyond what the AT can deal with, but for most aggressive launches it will compare well.
The trap times all end at barely above 100mph. Like I said, at this point in the "race" the 6MT has just selected 4th gear at 99mph and is at a 21% advantage in torque at the wheels as soon as the 5AT hits 106 and selects the much longer 4th. At 102mph, the 5AT is nearing redline in 3rd with a locked up torque converter providing no multiplication. If let the race continue for a little longer the 6MT will make plenty good use of that 21% 4th gear advantage.
I stand by my comment that the 6MT will easily win 60-95. I picked 95 because both cars are in 3rd up until that point and the 6MT has a 6% advantage in torque at the wheels.
The discussion is fun, as it makes me think about cars and physics, both of which I really love. But... it's pretty moot. It comes down to feel and what you prefer. I don't like how a AT feels off-throttle. I don't like having to ride the brake down a hill. I don't like the manual downshift taking longer than it should sometimes and somtimes mysteriously revmatching incorrectly. I _prefer_ to deal w/ the 6MT.
The 6MT is faster though, period. The math doesn't work any other way. You will have to prove to me that the 5AT torque converter somehow multiplies torque while locked up (?!?) to make me think otherwise... the gears are shorter and all else is equal. No way the 5AT is the same.
Here's another thing you forgot to mention... driver skill. Not every driver who drives a 6MT G37 has the skill (or the time to practice) to launch and shift gears fast enough to beat a 5AT. I know people who drive a stick as their DD, and they hold down the clutch at red lights?! Mind you, I drive a stick everyday myself (not a G though yet). Not every 6MT driver is as good as they think they are! I can heel and toe and all that but, I am no harley haywood ( he has actually said he bought and preferred the 911 in the 5AT) and I have not met any G owners who think they can shift as good as he does. Still as long as you and everyone who has a 6MT enjoys it... I am happy for you guys. One love.
  #168
likwidfuzion's Avatar
likwidfuzion
All you're promoting is a pissing contest that won't get anywhere as can be seen with 12+ pages of arguing and bickering.
Solution: drive both transmissions yourself and get a first-hand experience. Hell, time yourself if it floats your boat. Compare and contrast. Problem solved.
In the end, the driver is the performance factor.
Old 09-13-2007 | 07:22 PM
  #169
kg37's Avatar
kg37
The driver was what matters for sure. I too believe that after the OP drives both cars, his choice will be clear then.
Old 09-13-2007 | 07:40 PM
  #170
leeI35G35's Avatar
leeI35G35
Well for my first manual car, and 20 days of ownership not being able to race the car with the manual, I LOVE FREAKING MANUAL. Had to rub that in. I go to work in traffic, and come home in traffic. Those little bit of spirts that allow met to get on the gas and clutch is so freaking enjoyable. Until they put neutral and reverse to be selected by the (fake F1) paddle shifters, I will not go back to auto ever again unless I have some kind of DSG, or AMG BEAST.
Old 09-13-2007 | 08:11 PM
  #171
ABQG35c's Avatar
ABQG35c
Hmm....
Old 09-13-2007 | 08:17 PM
  #172
EJ2000's Avatar
EJ2000
Holy Crap!!!!!!!! I just picked up my new G37 6MT... and it is awesome!!
So much smoother than the G35 I love it. Pics to follow but now I've got vb....
Old 09-13-2007 | 09:28 PM
  #173
Comatose's Avatar
Comatose
Regarding the magazine/calculator racing going on in some of the posts of this thread -- we shouldn't need this anymore should we? the G37 is out, many of you guys have it already. When are some of you guys gonna meet up at the strip and get this debate hammered out?
Old 09-13-2007 | 11:04 PM
  #174
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Well if you don't beleive the actual numbers that have been posted and supported by by multiple tests and if you think that the 6MT is going to produce significantly better numbers than what has been posted thus far then I say you are the one misinforming the group on this public forum.
It is my understanding that the TC in the G does not automatically lockup so quickly in 3rd gear. There was also an article that was comparing the 335 to the G37. It said that the 335 kept the TC locked most of the time and indicated that the G37 did not depending on the load. Not all torque converters lock up the same. In fact the G37 includes a "new calibration and modified torque converter characteristics" even vs the Sedan. I cant say for sure exactly how the TC in the G works but that is the only explanation for the 5AT to produce the numbers that is has (in 3rd gear). The mere fact that is rev matching downshifting into 3rd gear from higher speeds is indication that it is not always locked up in higher gears. This has been the case in both the Sedan and now the coupe. If the 6MT were truly that much faster, we would see it by now from results in at least the Sedan- its been out for a while.
The conditions of both tests that I posted are were good conditions and about the same (humidity temperature etc) so there is no reason for me to think that we will see sugnificantly better better times from the 6MT. All of the major magazines have all produced their stats.
You keep saying that the 6MT leaves the 5AT in 3rd gear. However you have already confirmed that the 6MT is in 4th gear at the quarter mile mark which is basicaly reaching that mark at the same time as the 5AT. By your logic of there being a significant difference of 60 - 95 because of 3rd gear the 6MT should be much quicker to the quarter mile mark even if the trap speeds are the same. You can't say that it is not apples to apples when there have been multiple tests producing the same or extremely similar results. Granted there may be some slight differences based on conditions- and they are indicated in the results- but even with the differences in conditions they very similar results with no "significant" difference.
In response to your implication that I am misinforming to "feel better" about my decision, and that you are calling me out PHALEESE!!!! (and I thought our discussion was pretty civil up until that point) let me just respond by saying that it was you who presented baseless information with your "annihilation" comment and that the 6MT was "much faster" and with your highly sophisticated butt dyno ("feels faster"). And your latest response sums things up with "I don't care if the numbers don't show it YET". When they do then come find me. I will admit I was wrong.
In closing I say see you at the track.
Old 09-13-2007 | 11:11 PM
  #175
mal_TX's Avatar
mal_TX
The calling out was not directed at you but in general that fellow seemed to think it was a problem for us to discuss and debate. I have a good deal of respect for you, Kahboom.
Now.. as to TC multiplication. I think you are wrong about your claim that there is torque multiplication happening in the TC at speeds above "launch" speeds.
So, I'll go read up on TC torque multiplication and get back to you. If I prove to you that it is not happening, and it's the "only" explanation for the numbers... then what? Will you at least accept the possibility that the 6mt numbers are low/slow so far and maybe that's why the 5AT looks so quick by comparison?
Old 09-13-2007 | 11:14 PM
  #176
mal_TX's Avatar
mal_TX
I'm not claiming this is conclusive because it is only two minutes of research on How Stuff Works, but:
http://auto.howstuffworks.com/torque-converter4.htm
"In addition to the very important job of allowing your car come to a complete stop without stalling the engine, the torque converter actually gives your car more torque when you accelerate out of a stop. Modern torque converters can multiply the torque of the engine by two to three times. This effect only happens when the engine is turning much faster than the transmission."
When would the engine turn much faster than the transmission, and when would it not?
And, in response to recent criticism about some supposed bickering... to the original poster -- anytime you want me to shut up you just let me know. I don't have any personal stake in this discussion so the minute it stops being of any benefit you tell me and I will go elsewhere
Old 09-13-2007 | 11:17 PM
  #177
kg37's Avatar
kg37
[QUOTE=leeI35G35;2225229
I will not go back to auto ever again unless I have some kind of DSG, or AMG BEAST.[/QUOTE]
I said the same thing too once...
Old 09-13-2007 | 11:26 PM
  #178
KAHBOOM's Avatar
KAHBOOM
I apologize and take my comments back then..
hey there are always the possibilities that ther could be faster times awaiting to be reported.... I will respond to your other comments later... I just wanted to quickly apologize for lashing back when I wrongfully thought you were disrespecting me
Old 09-14-2007 | 12:42 AM
  #179
ABQG35c's Avatar
ABQG35c
Would I be dumb if I waited later this year for the IS-F from Lexus?
Old 09-14-2007 | 12:46 AM
  #180
mal_TX's Avatar
mal_TX
If you can afford the IS-F... WAIT!
Quick Reply: 6MT or 5AT
