IP/Graphite picking up tonight!
#109
after receiving a couple of PMs. i'm attaching a pic of Superbrightleds.com's page that shows the LEDs that i bought.
this is where they are located: http://www.superbrightleds.com/cgi-b....31602&next=50
see attached.
edit: forgot to mention. when choosing color, select "White" or "Cool White" if the option exists.
see attached.
#110
see attached.
see attached.
#114
Finagle,
Do the LED's in your map lights have a soft glow even when the lights are off? I put mine in last night and even when the lights aren't on, you can see a very slight illumination coming from the bulb.
I plan on taking an electrical tester to the bulb socket tonight to see if there's trace voltage, but I don't know why there would be.
#115
Finagle,
i already knew this would happen from reading threads in the 07 Sedan section of G35Driver though. my fiance and i both think it kinda just adds to the ambiance lighting already present and doesn't bother me.
#117
I changed my lights like finagle last night as well. The doors were a PITA since I was scared I was gonna crack the lenses. lol Anywho thanks finagle for showing us which LED's to get, the car looks sooooo much better with the new lights.
When you guys turn on the headlights at night, is there a small hole with a light coming through next to the right map light? I didn't find out about it until last night.
#118
That light is an LED that provides ambient light on the center cluster... lets you see more than just the backlit controls at night.
#119
(2) 6 LED Bulbs - Map Lights
(5) 5 LED Bulbs - Trunk, License Plate
The 6 LED in the trunk gives a spot-light effect with one brightly lit circle on the trunk mat while the 5 LED in the trunk softly lights the whole area. Ditto for the doors.
