will the 6MT come with push button ignition?
I don't see why It wouldnt.
Push to start ignition works different than remote ignition on the 06 auto coupe.
(You will probably never see a remote ignition on a MT; its not smart)
Originally Posted by Zee2G
Sedan with 6mt does have push button start. I would expect the coupe to be the same
Traveling Administrator
![](/images/premier.gif)
Originally Posted by FAST1
So the FOB can remain in your pocket when you push the start button?
![Cool](https://www.myg37.com/forums/images/smilies/cool.gif)
According to the show babes (models for those of you who are offended), yes, and its not like the bmw 335 system that requires you to put it into the dash slot in order to use it, it only has to be in proximity to both unlock the doors with the push of the door handle button, but also use the push button start. Not a James Bond 30 Cal under the lights, but nifty...
So the FOB can remain in your pocket when you push the start button? The dumbest scenario is that one car, can't recall which, requires you to insert the FOB into a slot before you hit the start button.
There is a slot to put the intelligent key in, but only time you need to put it in the slot is when the batteries in your intelligent key are dead.
Originally Posted by g35sedan5at
yup...got in my friends brand new mini cooper eysterday and the damn thing requires that u stick this flying saucer looking FOB into the car, and then apply the brake, and then push the start button.lol. damn bavarian motorworks (i think its motorworks)
Originally Posted by AdamJ
Does the AT5 G37 even have push button start? Or do you still have to turn the ignition switch even when there is no key in it?
