what will 0-60 be? in 08 g37
#226
#227
Car and Driver just tested it at 5.3 seconds 0-60. Too bad because they tested the 07 G35sedan at 5.3 seconds!
That's a screw up! Infiniti should have bumped up the car to do 4.9 seconds and put the 335i and others to shame.
#228
Yin-Yang and Life
Welcome to the forums, tat. I'm too tired of this subject to even debate it... it has been beaten to death.
#231
Originally Posted by Hypnoz
I believe the stock E46 M3's dyno around 265-270whp. The weight difference is negated and they are thus nearly equal hp:weight.
I'd have to do some digging to find which mag actually said it, but if you really want I will. They are all biased. Most towards bimmer.
As I indicated, the M3 is better handling than the 335. The G37 (could be) slightly better handling than the 335, which could bring it close to the M3.
Let's just wait and see. No point in magazine racing for days on end... I can see now why most people don't take part in it.
#232
Location: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
2003-2006 specs of g35 vey close
Engine : V6, DOHC, front mid-engine RWD
Displacement : 3,498 cc
Valve : 24 valves, 4 valves per cylinder
Transmission : 6-spd manual, 5-spd automanual
Fuel economy : city - 19 mpg
highway - 26 mpg
Suspension : F - Independent multilink
R - Independent lower link A-arm
Brakes : F - Vented discs
R - Solid discs
Horsepower : 280 hp @ 6200 rpm('03-'04),
298 hp @ 6400 rpm('05-'06 manual), 280 hp('05-'06 auto)
Torque : 270 lb-ft @ 4800 rpm('03-'04),
260 lb-ft @ 4800 rpm('05-'06 manual), 270 lb-ft('05-'06 auto)
Redline : 6600 rpm
Top speed : 155 mph(electronically limited)
0-60 mph : 5.6 sec.('03 manual). 6.2 sec.(auto)
0-¼ mile : 14.2 sec @ 100.5 mph('03 manual)
60-0 braking distance : 117 ft
200 ft skidpad : 0.92 g
Curb Weight : 3416 lbs
Overall length : 182.2 in.
Wheelbase : 112.2 in.
Overall Width : 71.5 in.
Height : 54.8 in.
highway - 26 mpg
R - Solid discs
Redline : 6600 rpm
Height : 54.8 in.
#233
highway - 26 mpg
R - Solid discs
Redline : 6600 rpm
Height : 54.8 in.
highway - 26 mpg
R - Solid discs
Redline : 6600 rpm
Height : 54.8 in.
#234
04-11-2007, 04:22 AM
da45king
Registered User Join Date: Oct 2004
I'm guessing a pesimistic 5.3 0-60 by road & track for the 6mt(5.5 auto)
and 5.5 0-60 for motor trend for (6mt) 5.7 for auto....mt numbers are usually slower.
Magazine testing is flawed. my supposed 5.8 0-60(with simple intake an exhaust with 100k miles on it) car consistently beats the **** out of a 5.3 0-60 car (z).
da45king
View Public Profile
Send a private message to da45king
Find all posts by da45king
Add da45king to Your Buddy List
don't get a cookie for this prediction?
da45king
da45king
View Public Profile
#235
#237
That M3 was a beast and now that the V8 is coming out OMG
Actually if you go to the M3 forum, you'll find that the reaction to the E92 M3 by owners of the E46 M3 is more negative than the reaction of G35 owners to the G37. Lots of unhappy M guys. Again the expectations were sky high, and although the result was good, it wasn't spectacular, at least in the minds of many existing M owners.
#238
whether its 4.9sec 0-60 or more doesn't make me a difference. anyhow when they come up with these specs.. is the spare tire in? what kind of oil? gas? tires? road conditions etc. these things all have to be factored in. i know for sure with someone weighing around 250 they're not going to get 4.9 maybe 5.0 or 5.1 the G is fast enough stock for the money. just drive safe and enjoy the car. i now i will i mostly care about how the car accelerates after 80-90.. my brothers wrx sti acceleration drops to a crawl after hitting 110.. for me thats when it just starts getting interesting. the g37 sounds greater than the g35 at higher rpm.. hopefully will be faster at top end too....
#239
.......that's what I thought.
