G37 Tech Specs, Features & Options
#47
Let's face it most of us have ambivalent feelings about a car's curb weight. Sure we want a lightweight car, but of course we want an air conditioner, heater, etc., a larger displacement engine is a good idea, a back seat, air bags front and back and even on the sides are a good idea, we've got to have our moon roof, a great stereo system with at least 8 speakers is an absolute must, a nav system is great, a spare tire is nice, we certainly want our doors reenforced in case of a side collision, and we have to have a car that is at least 50% more rigid than the prior model since we don't want any flex in hard turns. OK Infiniti I want all of that in a 3200 lb car. Good luck.
#48
Originally Posted by FAST1
LOL The only thing being compared is the weight. The Cayman S understandably is a superior car for those who value handling above all else. Most performance cars that weigh as much as the G37 have at least 300 lb/ft. of torque. You are in for a very unpleasant surprise if you believe that 270 will do the trick. I believe the 335 has 300 lb/ft.
Not sure what you mean by "Do the trick". The current sedan does a 13.9 in the quarter mile which is plenty fast for the street. And that is with the 268 lb-ft of torque at PEAK (not across the whole rev range). The new coupe has about the same (270) but will be flatter. In addiiton, it stays higher for a longer time. Those two things together gets you more power down low and up high. The final gear ratio has improved much as well, which will increase low end torque as well.
I'm guessing about a 13.7-13.8 in the 1/4 mile, although I'm hoping for 13.6. The 335 puts out 300 lb-ft of torque but is a bit uderrated. It is putting out closer to 315 or so. That being said, if you look at it's torque curve it is flat from about 2000 rom to 5000 rpm, and then has a steep dropoff. So, it will feel very strong down low (a nice thing) but will make less high end power (the current G sedan makes more power up high than the current 335). My old G ran out of steam up high so I welcome the strong top end, especially if the 6-speed is truly improved and more refined.
Since I am shopping the 335 and this coupe, I am familiar with the 335. I have test driven a 6-speed, and know what it does well, and what it doesn't do well. No matter what the new G did it was never going to have a 300 lb-ft flat torque curve from 2000 to 5000 rpm AND make strong top end numbers. That being said, there were alot of things about the 335 that would annoy me over the long haul.
#49
Just looked at the interior specifications. Looks like the back seat lost a bit of room. 0.2 incles in shoulder, head, and hip room. 1.6" in legroom!! Back seat is officially useless. From trying to sit back there, it needed 1" more of head room and 1" more legroom, and it would have been exponentially more uselful. Losing space is the wrong direction.
#50
.....OK Infiniti I want all of that in a 3200 lb car. Good luck.
![Roll Eyes (Sarcastic)](https://www.myg37.com/forums/images/smilies/rolleyes.gif)
Guys, let's be real. These engineers already know the deal is. I'm sure that they've figured out most if not all the issues affecting perfromance and have made attempts to address those issues. It's not that it can't be done; it's just that it all boils down to the issue of $$$.
Of course, if you still insist to have all those goodies and then some then let me recommend this:
http://www.porsche.com/usa/models/91...turesandspecs/
http://www.edmunds.com/new/2007/pors...868/specs.html
Glass panorama roof; AWD, Bose sound system and a relatively low curb weight and the "prestige" of a fancy nameplate. All that for more than twice the price of the new G coupe.
![EEK!](https://www.myg37.com/forums/images/smilies/eek.gif)
![Cool](https://www.myg37.com/forums/images/smilies/cool.gif)
![Big Grin](https://www.myg37.com/forums/images/smilies/biggrin.gif)
![Wink](https://www.myg37.com/forums/images/smilies/wink.gif)
#52
Torque in and of itself doesn't mean much. Torque is simply the force applied at a specific instant -- what's just as important is how many times that force can be applied over a given period of time (rpms), which determines how much ACTUAL work can be performed by the powerplant (hp). Therefore, it doesn't make much sense to say that X amount of torque isn't sufficient. 270 ft-lbs w/ a redline around 8000 is plenty and is very much in line with the sportscar concept.
#53
Originally Posted by skaterbasist
Wow, so much weight.
Yet it still manages to outhandle the 335i.
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
#54
Originally Posted by Mr_Ryte
Indeed.
That is a trade I think most of us would be willing to make if Infiniti did it (instead of adding weight). Especially considering how easy it is to make power in the aftermaket, and how difficult weight is to drop.
It just seems that Infiniti is more overly concerned about luxury over sport and sports car feel. Not that is a bad thing, just not exactly what I was hoping for.
#55
I'll buy 13.7 or 13.8 and if that is good enough for you, then the G will meet your expectations. Personally I was hoping that the '08 G37 would at least match the performance of an '07 335, and that means around a 13.4 1/4 and 0/60 in 4.8 secs. As far as making power at the top end, well that's useless for the vast majority of drivers since they spend 99.999999999% of their time driving below 5K RPM. For the street BMW has it right since it puts out a great deal of useable torque where drivers need it: 2 - 5 K RPM.
#56
Originally Posted by TRIG
It's the limited slip diff. BMW don't put LSD in the 335i because they don't want it to directly compete with the M3. ![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
(This logic is not to be confused with BMW's logic of not including an alarm with the vehicle or making runflat tires the only tire available on the 335i.)
#57
If you guys want to count tenths of a second and weigh down the ounces for every bit of performance, the folks at Nissan/Infiniti would likely steer you towards the Z. Same engine/transmission/brakes, etc... Cheaper, less weight, less luxury. Simple. The G is NOT a sports car, it's a luxury cruiser. Sure I want it to have 450hp and weight 3400lbs also... But get real.
Plus, we'll have Vortech superchargers out for it in no time.
#58
Plus, we'll have Vortech superchargers out for it in no time.![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
#59
Will the '08 Z have the 330 HP engine?
And yes, the G is more of a Grand Tourer than flat-out luxury car or sports car. Even so, it still leans more towards the luxury side of the Grand Tourer scale. Whether that's good or bad depends upon the potential owner.
