Need some more space in my G vert
I have a 09 G37s Vert manual transmission. I have a market business where I cook food. I bring a tent, coolers, foldable tables, and boxes of other supplies. I have to make two trips in order to get everything to the market. I can fit most everything in one trip but the 4 foldable tables can't fit in with it all so I usaully come back for the tables and maybe a water dispenser. Any recommendations for space? Trailer? Roof attachment? Back cargo carrier? Get a rv or truck..? Hopefully one day I get a food truck but until I can invest in that I'll need another option.
Ideally, find yourself a small pickup. A pickup truck will:
Many folks have added trailer hitches to their cars- albeit none that I know of in a 'Vert. While Infiniti does not recommend towing a trailer of any kind, as long as you stay within the GVWR (Gross Vehicle Weight Rating) of the car (should be on driver-side door jamb label) you should be fine. It is not something I would do, but it can be done. Just my 10¢...
- be easier to load;
- have enough capacity to SAFELY & SECURELY haul everything you need to carry;
- cheaper on gas; and
- save wear and tear on the 'Vert.
I am quite confident that even in the current nutty used car market you could find a barebones CR-V or RAV4 that would suit your needs fully. It does not have to be the "top-of-the-line" or even the newest, but a reasonable vehicle can be found... (crosses fingers)
I just do not see the 'Vert being practical for this type of task. In a pinch, perhaps, but as a matter of routine definitely not.
Good luck- with the business and search- and, please let us know how you make out.
GDriveAlot
01-31-2022 09:47 AM
Poe408
12
12-23-2010 04:54 PM
