Is Infiniti Dumbing Down the HP Rating on the 'Vert?
#31
Do a search they are out there. Also check out my350Z and driver in the Sedan section. Vendors have likewise made similar observations. I have searched and posted these a couple of times in the past. I'll let someone else do the research this time
edit.. so I lied.. Here is the link to the G35 dynos. Particularly look at the 5AT HR dyno (second from bottom) and the 6MT
HR dyno (at the bottom). They are within 2 to 5 HP of eachother
http://g35driver.com/forums/1684290-post1.html
There are more out there with the G37 dyno'd that Gamedog and another member did as well as others.
I really dont see anything to fully conclude the previous statement in question.
#32
First of all, the two cars which were dynoed (for an MT vs ATX side by side) weren't even of the same year. 2007 vs 2007... in 2 years a lot of variables can happen to a car, including but not exclusive to the volumetric efficiency of the engine(s)... read: this can be a BIG factor. Secondly, I dont see any dates or times on the dyno charts in question. Now Ill give it that they were probably done at the same place, but who is to say these weren't days, weeks or even months apart from each other? And of course we are talking about two different versions of the VQ engine (G35 vs G37) as well as different transmissions.
Volumetric efficiency is not a measure of engine efficiency.... Going under the assumption that "there are a lot of variables between two engines of the same model", again, shouldn't all dynos NOT be comparable?
I still stand by my statement that any two cars dynoing on the same dyno with the same set of calibrations can be compared, if the same set of corrections are applied to both cars.
#33
Super Moderator of Pwnage
Additionally this is a dynapack with correction factors included so even if they were done at different times, they wouldn't be that far off.
The data is the data accept it or not.
#34
DYNO 5AT vs 6MT
Another set of dynos- these were done at different times but done on same machine with correction factors for a G37 coupe MT and AT.
https://www.myg37.com/forums/2314623-post1.html click the attachment in the post
https://www.myg37.com/forums/2481407-post8.html
Perhaps it is coincidence that each comparison of results done on the same machine with correction factors are so close?
Any other forums you look at- when correction factors are done properly for other cars- you can clearly see the difference between the MT and AT. I dont doubt that there is less drivetrain loss in the 6MT but the gap is not as wide as what is typical nor does it appear to be significant.
Thus further evident in the results mags achieve- such close times when testing the ATs and MTs in the G. Members have furthermore posted timeslip indicative of the fact th the two transmissions deliver remarkably similar power to the wheels.
#35
I thought HP rating was lowered because exhaust set up like sedan, with 2 mufflers.
According to this video, its set up same as coupe.
http://www.nicoclub.com/articles/vid...ottle-blip.mov
#36
#37
I turned the brightness all the way up on my monitor. It looks like the midpipe is similar (possibly smaller diameter???), but the rear muffler looks smaller. I would assume it'd have to because the hardtop needs alot of space, and the spare tire well would have to be lowered?
#38
#39
The hard top itself is pretty much all above the frame/exhaust so I doubt that it has anything to do with the exhaust changes. However the structural reinforcement done to the frame/chassis is the likely culprit as they have to strengthen the frame when you have no integrated top.
#40
My guess would be Nissan is still "playing" with the fuel economy numbers on this
specific model in order to achieve the highest "fleet mileage" possible. CAFE standards
don't give the manufacturers "wiggle room" to manipulate HP ratings for the
sake of marketing any longer. I can think of several manufacturers who were forced
to advertise decreased HP ratings by as little as two HP over the last decade.
When a manufacturer says "at least" they mean it. Once they optimize the
mechanical components of a given model to the real world CAFE tests, they will provide a specific HP output for that model....that's ONLY ONE reason you see variances betweeen two exact displacement engines in two different models.
#41
From 2009 Infiniti G37 Convertible - First Drive Review - Auto Reviews - Car and Driver
"The sonorous 3.7-liter DOHC V-6 carries over from the coupe, with peak output of 325 hp coming in five fewer than the hardtop’s, thanks to some exhaust changes."
It doesn't talk about it in this article, but I thought it had to do with re-routing the exhaust because of some of the structural changes needed for the convertible.
#43
its from the exaust. its wayyy quiter than normal, my 04 G35 rumbles when u drive with the windows cracked or down, did the same with my vert and i could barely hear the usual "roar" they make at 2500-3000 rpms. looks like my 1st mod is definitly gonna be the exaust for this car, then the spoiler cause i cant stand that damn short antenna.
ZSpeedPerformance
Supporting Vendors
09-04-2015 11:09 AM
