FS 2010 Supercharged G37X (PA) PLEASE READ DESCRIPTION
SOLD 2010 Supercharged G37X (PA) PLEASE READ DESCRIPTION
Year: 2010
Make: INFINITI
Model: G37x Sedan
Price: $10000
Mileage: 96000
Color: Slate Blue
Location (State/Prov): PA
2010 G37X Sedan with Stillen supercharger kit and a Stage 2 Snow Performance Methanol kit. There is A LOT of good parts in this car and it's very very very cleanly done down to the wiring on everything. Most of the go-fast parts have less than 3,000 miles on them. It's been sitting for a year and a half because I haven't had time to drive it. I got it out and took it for inspection (which it passed here), however it's randomly stalling at idle and we believe one or more of the injectors is sticking from gunk buildup. Easily $12k in used value parts value. It runs and it drives strong when it's not stalling. However I'm starting a new job and I have no time to deal with this car anymore. No dash cracks or anything, there is a 1" split in the door panel vinyl from age.
As far as being tuned, it was tuned by Eugene Turkov remotely and the 93 pump tune is basically complete. The methanol was installed after the fact, it was test sprayed into atmosphere, the system is working as expected but it will need to be tuned to take advantage of the additional cooling and/or timing that can be used from it. Due to the stalling I would highly recommend towing it out. All this build really needs is a VR30 trans swap to make it bulletproof and an A2A kit if you really want to push it. Have some spare extra parts too for it, taillights, a rear brace, the OEM steering column and dash accents, etc. Car is garage kept. Full parts list below:
Go fast:
ISR Test Pipes
Hall Built Performance Single Exit Catback
Vortech Supercharged
Frozenboost Heat Exchanger
Turbosmart Kompact BOV
Upgraded Jackshaft Pulley (11psi)
Injector Dynamics 1050cc Injectors
Snow Performance Stage 2 Meth System
Large Capacity Methanol Tank in Trunk w/ Level Sender (Gauge flashes yellow when level is down to 1/3)
Motion Raceworks Boost Ref Manifold
LOJ Billet Flexplate
ARP TC Hardware
CJM Fuel Tap Block
CJM Billet Fuel Hat
Radium Engineering Fuel Surge Tank
Dual Fuel Pump Aeromotive 340 (in tank) and AEM 50-1200 (in surge canister)
Mocal 26 Row Oil Cooler
Setrab Sandwich Spacer
EPS Gallery Gaskets
R35 GTR Spark Plugs
Ecutek RaceROM Tuned
Swift Springs
SPC Camber and Toe Hardware
Hotchkis Sway Bars
Cusco Sway Bar
Akebono Caliper Upgrade
R1 Geomet Slotted Rotors
Powerstop Stainless Brake Lines
Misc:
Carbon Fiber Steering Wheel
Hydrodipped / Wrapped Interior
Padholdr Tablet Mount
Q50 Shift ****
GlowShift Fuel Pressure Gauge
VLS Oil Pressure Gauge
Custom Front Splitter
EZ Splitter Side Splitters
Custom Rear Spats
Stillen Spoiler
Stiller Roof Spoiler
Wrapped Roof
Retrofitted Halo Taillights
Long Acre Racing Splitter Supports
Niche M157 19x8.5's with Dunlop HP Tires still with lots of life left
OEM Paddles w/ Force Carbon/Kevlar Paddle Extensions from Shift Konceptz
Professional painted OEM grille
SwiftKit (07-14-2022)
