FS Athens Blue G37S Coupe - Tastefully Modded
Year: 2008
Make: INFINITI
Model: G37 Coupe
Price: $12250
Mileage: 105000
Color: Athens Blue
Location (State/Prov): MO
This severely pains me to do this as I have loved these cars since they were released years ago but, I started a small business and need to keep my priorities in order for awhile. So, I’ve put about 9k miles on it in the almost 2 years I’ve owned it and is currently at 105,xxx. I have only run 91 octane or better since day one. This was never a daily driver, I own 2 other cars that I drive to work and in the rain/snow. I keep it garaged all day/every day, it hasn't seen rain since I’ve owned it. The interior is immaculate, the exterior could use a good detail but there are no major scratches or dents whatsoever. I do all of my own mechanical work and will list out the modifications I have installed:
Carsmo stainless radio *****
JL Audio 250 watt amp and 8” subwoofer
Top Speed axle-back mufflers
Top Speed revised Y-Pipe (stock y-pipe included)
Beluga test pipes with o2 extenders (stock cats included)
Injen cold air intake (stock intakes included)
KDS Customs blacked out headlights and FX-R clear lense
Blacked emblems and grill
OEM Infiniti brake rotors front/rear
Hawk HPS 5.0 brake pads front/rear
Motul 5.1 Brake Fluid
Tein S-Tech lowering springs (stock Sport springs included)
Tanabe rear springs (can be installed to raise/level the rear, not installed but included)
SPC camber bolt kit
Avant Garde M310 wheels - 19x9.5” Front/19x11” Rear
BFGoodrich G-Force COMP 2 tires, 85% front / 25% rear remaining
Full LED bulb conversion
Diode Dynamic LED taillight mod
Nissan OEM FXE24HR11 spark plugs
Hood/trunk struts
RainX windshield treatment and wipers
All of these parts total well over $5k and were installed at some point in the last 9k miles. I’m sure I’m missing a couple of things but that should cover most of them.
Now, like anything, there's always some things I feel I should mention.
The driver side window tint is peeling in one corner, I was quoted $45 to peel and replace.
One headlight was reinstalled a bit misaligned after getting blacked out, if I get a chance before selling the car, I’ll remove the bumper and set it straight but it's barely noticeable.
2 aftermarket switches were installed on an interior trim piece from the previous owner for fog lights and a subwoofer. I have since removed the fog lights and had the subwoofer rewired to power on with the radio and have never removed the switches. The aluminum trim piece can easily be replaced for $20 on eBay.
The dealership branded sticker on the trunk peeled off and left some residue, I haven't had a chance to remove it and buff it out. It would be a free fix with some elbow grease and 30 minutes.
I recommend getting an ECU flash from UpRev. The car drives like a dream as-is but with the amount of parts installed, it would probably gain 20-30 horsepower along with better gas mileage.
The front license plate bracket was bolted directly into the front bumper. It's required to run a front plate in Missouri so it doesn't really matter but I never did and always noticed those 2 little holes in the bumper. If you're a law abiding citizen, this won't matter.
![Wink](https://www.myg37.com/forums/images/smilies/wink.gif)
I replaced the fender liners in the front once already but, the bigger wheels/tires rub against them and have rubbed some holes into them. This has no effect on the car but unless you get thinner tires, there's no point in replacing them again.
The cold air intakes included an aftermarket washer fluid reservoir to be custom fitted. Since I never drive in the rain or let my cars get dirty, I removed the reservoir all together like most other G37 drivers had suggested. I will include the uninstalled OEM reservoir as well as the aftermarket reservoir with the car so you can decide what to do with them.
THAT’S IT! I think these are all very minor “issues” and haven't bothered me in the time I’ve owned the car but I feel it’s best to be honest and to avoid any surprises.
I am asking $12,250 with all of the parts and wheels installed/included. Feel free to make offers with/without some parts, I have no problem selling off some things to help you with the price.
I can be reached at 417-619-5341- Thanks!
