Got UTEC?
Old 06-23-2006, 05:15 PM
  #31
Down_Shift
Down_Shift's Avatar
The only 2 things not installed are the Utec and the Spacer...
Can you post some pics of the vac line etc? Might be diff on my car as they had to plug that for boost etc.
Down_Shift is offline
Old 06-23-2006, 09:32 PM
  #32
Audible Mayhem
Performance Factory
Audible Mayhem's Avatar
most of the time, you just cut any of the vacuum lines and T into them. pretty simple, they all read the same pressure/vac.
are you sure you wanna put a plenum spacer on there boosted. it doesnt really do much for FI and will actually add more room inside for the boost to fill before you make power....
Audible Mayhem is offline
Old 06-30-2006, 02:48 PM
  #33
Down_Shift
Down_Shift's Avatar
Install was a breeze.. I still can't get the Utec and ECU under the dash together.. ugh..
My car is running REALLY rough.. Might have a bad utec on my hands..
