Vendor MOTUL Engine Clean Additive
Old 02-26-2011, 08:15 PM
JEBperformance
JEBperformance's Avatar
MOTUL Engine Clean Additive, Now available from JEB Performance.
The MOTUL Engine Clean is additive where you add to old engine oil prior to changing to new oil. Run idle for 20-25 minutes. And will clean all the deposits, and sludge. While oil is drained to be replaced by new ones.
Motul engine clean will not only clean piston bay, but also other small breather points inside your engine.
A normal oilchange when drained will leave deposits. Later to contaminate new oil.
Now when all the impurities are drained with old oil. To run your oil fresh, new, and for longer life. Reduce oil and gas consumption.
I know this for a fact. My customer's STI consumes about a quart of oil each and every month. Common problem with Subaru Turbo Engines. Flushing old oil with MOTUL Engine Clean, reduced oil consumption by more than half. Oil consumption as we may already know, increases with longer use of your vehicle. Older they get more oil and gas consumption. Is result of your engine accumulate more and more deposits.
Cleaning your oil, or flushing all deposits maintain performance. Equalizes all cylinders to fire with higher and equal compression. Prevents wear and tear on engine parts.
MOTUL Engine Clean is a care system for your Engine. Which is as easy or easier than your OIL CHANGE. Motul recommends Engine Clean on each and every oil change. However every other oil change is good enough.
<embed id="VideoPlayback" src="http://video.google.com/googleplayer.swf?docid=613819500230207789&hl=en&fs =true" style="width: 400px; height: 326px;" allowfullscreen="true" allowscriptaccess="always" type="application/x-shockwave-flash">
ORDER NOW MSRP $21
Single Oil Change
Case of 12 + FREE GROUND SHIPPING
Old 02-26-2011, 08:47 PM
AvosG37
AvosG37's Avatar
sorry, can u explain me little bit? i am deaf. do u add this with oil?
Old 02-26-2011, 09:09 PM
JEBperformance
Sorry man. The Motul engine clean is additive where you add to old engine oil prior to changing to new oil. Run idle for 20-25 minutes. And will clean all the deposits, and sludge. While oil is drained to be replaced by new ones.
A normal oil change when drained will leave deposits. Later to contaminate new oil.
I know this for a fact. My customer's STI consumes about a quart of oil each and every month. Common problem with Subaru Turbo Engines. Flushing old oil with Motul Engine Clean, reduced oil consumption by more than half. Oil consumption as we may already know, increases with longer use of your vehicle. Older they get more oil and gas consumption. Is result of your engine accumulate more and more deposits.
Motul Engine Clean is a care system for your Engine. Which is as easy or easier than your OIL CHANGE. Motul recommends Engine Clean on each and every oil change. However every other oil change is good enough.
Old 02-27-2011, 01:02 AM
JEBperformance
PM sent, good idea I will put them on your Hotchkis Sway Bar Box. To save some shipping cost to Canada.
Old 02-27-2011, 01:41 AM
JEBperformance
Payment received thank you.
Old 02-27-2011, 03:32 AM
AvosG37
AvosG37's Avatar
thanks a lot. they sound good! PM me 91504.
Old 02-27-2011, 05:22 PM
JEBperformance
PM sent, thank you for the opportunity
Old 02-28-2011, 03:17 PM
JEBperformance
BACK TO TOP on This Beautiful Monday
Old 03-02-2011, 01:10 PM
JEBperformance
Thank you for choosing JEB Performance
Old 03-02-2011, 01:57 PM
JEBperformance
PM sent, thank you
Old 03-04-2011, 12:25 AM
JEBperformance
Please do not get confused with Motul Motorcycle Engine Clean. Offered only from JEB Performance is genuine specially formulated for Automobile USE ONLY. You will not find elsewhere. If you do your research the content volume is double of the motorcycle.
Old 03-07-2011, 01:59 PM
JEBperformance
All PM responded. Proven once again. From JEB you only get best products.
Old 03-08-2011, 02:28 PM
JEBperformance
Only true clean oil change with Motul Engine Clean Additive
Old 03-08-2011, 11:07 PM
Staples
Staples's Avatar
I've used this stuff in the past, I use it about once every 3rd oil change just to give that extra clean factor. This is a must, especially anyone that is switching from the dealership's dino oil.
Old 03-09-2011, 02:38 PM
JEBperformance
I use once a year. When changing from MOTUL 5W30 to 10W40. Just before summer heat.
Quick Reply: Vendor MOTUL Engine Clean Additive
