Vendor MOTUL Engine Clean Additive
MOTUL Engine Clean Additive, Now available from JEB Performance.
The MOTUL Engine Clean is additive where you add to old engine oil prior to changing to new oil. Run idle for 20-25 minutes. And will clean all the deposits, and sludge. While oil is drained to be replaced by new ones.
Motul engine clean will not only clean piston bay, but also other small breather points inside your engine.
A normal oilchange when drained will leave deposits. Later to contaminate new oil.
Now when all the impurities are drained with old oil. To run your oil fresh, new, and for longer life. Reduce oil and gas consumption.
I know this for a fact. My customer's STI consumes about a quart of oil each and every month. Common problem with Subaru Turbo Engines. Flushing old oil with MOTUL Engine Clean, reduced oil consumption by more than half. Oil consumption as we may already know, increases with longer use of your vehicle. Older they get more oil and gas consumption. Is result of your engine accumulate more and more deposits.
Cleaning your oil, or flushing all deposits maintain performance. Equalizes all cylinders to fire with higher and equal compression. Prevents wear and tear on engine parts.
MOTUL Engine Clean is a care system for your Engine. Which is as easy or easier than your OIL CHANGE. Motul recommends Engine Clean on each and every oil change. However every other oil change is good enough.
<embed id="VideoPlayback" src="http://video.google.com/googleplayer.swf?docid=613819500230207789&hl=en&fs =true" style="width: 400px; height: 326px;" allowfullscreen="true" allowscriptaccess="always" type="application/x-shockwave-flash">
ORDER NOW MSRP $21
Single Oil Change
Case of 12 + FREE GROUND SHIPPING
ORDER NOW MSRP $21
Single Oil Change
ORDER NOW MSRP $21
Single Oil Change
ORDER NOW MSRP $21
Single Oil Change
