Help Clutch Replacement
Clutch Replacement
Looking to upgrade clutch... sticking with DMF as drivability is important for street driving...question on the following:
Are others moving to CMAK setup or CSC HD upgrade? I have have the CSC HD V1 now (been 10 years strong!) so im new to the CMAK upgrade.
Flywheel and Pressure Plate Bolts - Are you guys replacing with ARP for strength or reusing stock bolts? Mine have about 90k on them so figuared id ask if its a worthwhile upgrade
Replacing ACT HD clutch which as been awesome, I see they have an extreme line that claims to hold to 545 TQ level.....Any have and enjoy?
Thanks for the help!
When it was time for mine, I went with a Stage 2 clutch from ZSpeed. South Bend IIRC makes theirs. Slightly stronger sprung cover plate and sprung hub disc, on a lightweight steel FW. Also went with the ZSpeed HD CSC, line, and the ARP bolt set that ZSpeed sells (they basically have an install kit with redline/motul fluids and all the hardware). For what i was spending on labor, made sense to replace everything inside at once.
Prior to Infiniti, my go-to with RX-7s was the ACT HD on a Prolite flywheel, so I know that setup pretty well. I think the ZSpeed is a little softer grabbing, but power handling should be similar.
If I have any regrets, it's that I went with the 20# steel lightweight flywheel and I should have gone lighter. I don't really notice the LWFW at all.
CMAK for me wasn't an option because no one would install it and I don't have the resources to do a trans swap myself (IE, lift).
silverbulletg
10-24-2023 07:17 AM
steez
12
03-08-2016 01:45 PM
YNotRockAG37s
General Tech Questions
02-02-2014 12:47 AM
