Help 2013 g37 p0420
2013 g37 p0420
Howdy, I am helping a buddy with his 13' G37, and he has a P0420. I was thinking faulty o2 sensor, so I looked up the voltages and they line up with being fine, but the cat being bad. Can we get rid of the light with an o2 spacer, or is there any other cheaper way without replacing the cat
o2 Voltages when hot
o2 Voltages when cold
Here is a video of showing a good voltage graph of the rear O2 sensors from a G37:
Use this to compare it to your buddies.
Keep in mind, on the G37 the "sensor 1" is a wide band / air/fuel sensor and will output 2.2 volts with an AFR of 14.7 / lambda 1.0
The sensor 2s are the old school "o2" narrow band sensor and will output a voltage of almost 1.0 when rich, and almost 0v when lean.
lamchidinh
26
01-19-2021 02:09 AM
Mik3G37S
10-18-2013 04:15 PM
shumby
Intake and Exhaust
07-14-2008 08:33 AM
