Help Should I rebuild?
Old 08-19-2021 | 10:06 AM
Gug's Avatar
Gug
Should I rebuild?
Hey guys. I'm planning on doing forced induction in the near future. But I'm wondering, should I rebuild my motor first? It has 110k miles on it. So it would probably be a good idea I assume. But do you think a top end rebuild would suffice, or would I be required to do the bottom end as well? I'm not looking to chase big numbers. Any advice is greatly appreciated.
Old 08-19-2021 | 10:13 AM
RMB5190's Avatar
RMB5190
What are your power goals? If looking to go 450-500, do a leakdown/compression check and see where the motor is health wise. If all is good then full send.
If goal is 600+ then rods and pistons would be a good idea. Or, still go full send and when/if the block lets go do the rebuild then. Used VQs are 1-1500 so grab one, machine and build if the current one lets go.
Tune is going t be the real determining factor - go with some one reputable
Mojo_Dp
05-20-2020 11:25 PM
NOLA_G
14
11-18-2014 09:05 AM
nonsensez9
09-24-2007 02:57 PM
Quick Reply: Help Should I rebuild?
