manual g37 transmission issues
Old 07-26-2021 | 09:28 PM
Rileyw's Avatar
Rileyw
Lightbulb manual g37 transmission issues
My 2008 6mt g37 has some transmission issues.
My 6th gear went out a month ago. The shifter usually has no problems getting into 6th gear but when it does it either stays in 5th gear or neutral.
I had my clutch replaced because I needed it anyway, but that fixed nothing. Anybody know what might be wrong or any ideas?
(1-5 has no problems at all)
Old 07-26-2021 | 10:44 PM
sobeIPL's Avatar
sobeIPL
Not sure what’s wrong, but this part will 100% fix the problem.
The following 2 users liked this post by sobeIPL:
EMPIR37 (07-28-2021), Rileyw (07-26-2021)
Old 08-19-2021 | 10:10 AM
Gug's Avatar
Gug
Wow I have the same issue too, my 6th gear grinds like crazy unless I precisely rev-match. 5th gear does it sometimes but rarely. Honestly you should consider a rebuild, as these transmissions are insanely strong and finding a replacement will be expensive. Have you tried *correctly* double clutching into 6th? When I do that I have no issues.
zenneson
12-18-2016 10:05 AM
TEAMMI
36
02-17-2016 12:42 PM
carnacious
12-15-2014 10:37 AM
eksigned
07-14-2011 03:01 PM
Xcalibur
30
02-05-2010 11:07 AM
Quick Reply: manual g37 transmission issues
