Help Question about engine swap
Hey sorry for bothering but I have a question based on g’s. Well, I have plans to do a hr to vhr swap on a v36 sedan 6mt, cause I have plans to go for a turbo setup. so my question is, with motor, ecu, bcm and motor harness should be it for the swap? Also can I link the hr tranny to the vhr motor without any adapters or custom bellhousing?
please correct me on anything if I need anything else.
Moderador
Engine harness, VVEL ECU harness, you'll need to hardwire the harness to the car
Drivetrain wise no, it's all the same.
Some HR folks end up using a vq37vhr block on their HR heads for more power since it's easier than to deal with the wiring.
