Help Overheating and misfiring at idle after coolant value replacement
I replace the trash plastic coolant value connector after it blew out on me . I was going to bleed the system but after bring it back home and starting the car to let the coolant bleed the car idle was so rough it wouldn't stay on It was very hot after I started to start it again to bleed it. But now I'm thinking I messed something up with the motor. I have no CEL either. I'm so lost.
1) let the engine cool COMPLETELY! Preferably overnight.
2) check your oil- does it look "milky?" *** If the oil looks milky, STOP! Do not start your engine. That is a different issue entirely
In the morning;
3) check your coolant level- top off as needed and start the engine. Also check level in overflow tank.
4) does the engine startup/idle smooth or rough?
5) if she runs normally, you will have to "burp" the air out- there are several DIY threads on this procedure.
I am sure you have/had a air bubble in there which prevented the coolant from circulating normally. The engine is designed to shut itself off if the temperature exceeds safe operating limits. These engines are relatively bullet proof so you should be ok.
In the morning;
Kameronismyname (07-02-2020)
In the morning;
In the morning;
Anthony Rud
10-03-2020 06:06 PM
JohnsG37x
01-30-2016 04:29 AM
