Help RJM Clutch Pedal
Old 03-14-2020 | 08:18 PM
heedtheninja67's Avatar
heedtheninja67
RJM Clutch Pedal
I had a shop install the RJM pedal since they were doing a bunch of other things as well. There seems to be a lot of lateral movement on the pedal arm/elbow (everything except the base), and it's become a lot more apparent as I drive it. Like it'll slide up to 1/4" side to side if I leave my foot on it. Yes, I know I should've driven it around for 10-15 minutes before heading out, but I'm an idiot and wanted to get back to work... I've asked if they could take another look, but I wanted to make sure that this isn't normal. I took a quick look under and couldn't find anything that was loose or obvious. I'll go back under tonight and see if I can mess with some of the nuts.
Old 03-15-2020 | 01:00 AM
Gio37's Avatar
Gio37
You mentioned that the base seems to be ok but I would double check the nuts holding it to the firewall.
I know it was a little bit of a challenge to get to the bottom nuts and needed a couple of different extensions to get them nice and tight.
heedtheninja67 (03-15-2020)
Old 03-19-2020 | 03:21 PM
heedtheninja67
Edit: I talked to Ryan from RJM and he said to adjust the 7/16 nuts at the top of the arm. This firmed everything up.
Tankhieu6
08-12-2015 07:51 PM
sLADe781
General Tech Questions
51
06-10-2015 05:34 PM
bgoodman
03-04-2013 02:09 AM
PhilH930
02-18-2009 03:34 PM
Quick Reply: Help RJM Clutch Pedal
