Help Does this sound like my starter is sticking/not disengaging?
I am getting this metallic grinding noise on cold start ups. It will grind for a few seconds on cold start ups, then stop. I replaced the pulleys, belt, and tensioner so I don't think it's that. What do you guys think it is? 08 Infiniti G35x.
LINK: https://www.youtube.com/watch?v=Dn5J...ature=youtu.be
GDriveAlot (03-04-2020)
Changed the starter, still getting this grinding noise. I also started the car briefly without the serpentine belt on, and it still made the same grinding noise. Any ideas? https://youtu.be/DBYUyhf8obQ
We now know the sound is not from the a/c compressor, alternator, power steering pump or the starter.
I don't think the engine could make this sound... so that leads me to think the transmission. It does sound a little like a "hydraulic" type sound.
I don't think there is an automatic transmission dipstick on your car, so you can't easily check the fluid level.
Maybe take it to a shop and get the transmission fluid changed...
Other than that, I am stumped!
Removing the belt was a good test!
after listening to this video I would have to say it’s more of a whine sound then a grind sound. Now that you’ve eliminated all rotating components on the front of the engine, it sounds like your transmission fluid pump. My 07 sedan’s trans pump intermittently would whine on hard acceleration, then out of no where it literally sounded like a pulley bearing took a crap and I got left stranded in the middle of the country! I would definitely stick a stethoscope on the trans right at the bell housing mating point. If your really feeling froggy, unbolt the torque converter from the flex plate, push the converter back about 3mm and start it up see if that sound is gone! Good luck!
codeflux (04-24-2020)
Notfelix
10-08-2019 10:26 AM
Libster
07-22-2019 03:23 PM
brd_ptty
18
03-02-2008 03:51 PM
