Bad MAF vs. Vacuum Leak
Old 06-28-2020, 12:01 AM
  #31
Odin
Odin's Avatar
Originally Posted by SonicVQ
You have tried 3 different fuel pumps and still have low fuel pressure under load. I don't think it is the pump.
I assume you are using the factory wires, so they should be ok.
It is not your tune. The stock fuel system can provide enough fuel flow for the typical intake/exhaust bolt-ons.
(based on my calculations, the stock fuel system can support up to ~330 wheel HP)
If this was my car I would measure the voltage and current at the fuel pump while under load.
This does require special tools, but I think the next step is to verify the electrical side.
I do have a DMM. Do you think I could use the teeth test probes to measure while driving?
If so, anyone know the pinout of the harness?
Old 08-08-2020, 02:53 PM
  #32
Odin
Odin's Avatar
I tested the voltage of the pump under load. Never drops under 12v and the pressure still drops. :/
Old 08-10-2020, 11:04 AM
  #33
BULL
Moderador
BULL's Avatar
I don't want to mess you up even more but FYI
This was from a Titian
ILM-NC G37S (08-10-2020)
Old 08-10-2020, 11:13 AM
  #34
ILM-NC G37S
ILM-NC G37S's Avatar
Received 1,323 Likes on 1,073 Posts
I will never understand the logic of not having a serviceable fuel filter. Eventually all filters get dirty and clogged.
Slightly off topic, but...
Old 08-10-2020, 11:16 AM
  #35
BULL
Moderador
BULL's Avatar
Similar problem, low pressure under load.
Old 08-10-2020, 11:43 AM
  #36
BULL
Moderador
BULL's Avatar
It fits in the topic as well. Because every this filter sees new gas that unfortunately cannot do much for this gunk.
This same gunk will lower the pressure overall. It might be fine on light or part throttle since it is able to keep rails full just not at WOT.
It's worth checking it out.
The dilema here is that for those that know and need a way to fix this is. New housing or adding your own filter down the line.
As some here will dwell with E85 this will mean shorter intervals in the fuel department
I'm not saying this is your problem but if voltage checked out and you're meeting pressures at half of the time you have a restriction or possible leak between pump and housing
Old 08-10-2020, 12:42 PM
  #37
SonicVQ
SonicVQ's Avatar
Did you happen to measure the pump current at idle and under load?
I would expect the pump current to be lower under load than at idle.
Old 08-10-2020, 01:23 PM
  #38
BULL
Moderador
BULL's Avatar
Didn't get to. Per Nissan they always replace the sender for ANYTHING.
We hooked a manual FP gauge and it would drop to 30-40s erratically.
I took the assembly home and re used the pump in another project, this was what the filter looked like.
Old 06-29-2024, 08:57 PM
  #39
ddogg777
ddogg777's Avatar
I'm curious how this problem was resolved
dom_sinserious
23
09-26-2022 09:13 AM
coastalsquirrel
12-13-2014 08:09 PM
PR_G37
TSB - Technical Bulletins
08-23-2011 04:22 PM
sobi6111
10-22-2010 03:52 PM
Quick Reply: Bad MAF vs. Vacuum Leak
