Little help with operationing temp
Little help with operating temp
Hi all,
I've been searching for an answer to what the normal operating temperature should be for a g37 with no luck. It's been a bit chilly here in Charlotte lately and it feels to me that my g is taking longer than usual to warm up. I've got a gauge connected and I am showing about 179 degrees consistently. That's in stop and go highway traffic. I have replaced the thermostat with oem and drained the coolant with no change.
Is 179 the right temp? I would think it would be higher with a 180 degree thermostat. Would appreciate any information yall could share.
Thanks,
Jamie
Thanks,
Jamie
Maybe I should rephrase the question. For those of you with obdII readers, what temps do you see on the highway? Standing in traffic? Do you go over 180? If it's true the stock thermostat opens fully at 195, then I should see higher temps.
