Help! Coolant leak but no overheating
Leaking but I don’t know from where. Few months back I changed the heater hose connector ( plastic inlet that goes in between the hoses) Cars not overheating but I can smell the coolant.
I have a video of the leak. From the bottom of the car. Just can’t post it here. If you wanna see I can email it to you.
Check the weep hole. Mine leaked there during warm up. The o ring expanded on the water pump and sealed. No overheat but losing coolant. Needless to say pump needed replacing. May ad well do the oil gallery gaskets as well since the front timing cover needs to.come off to change the water pump
steez
14
06-19-2022 11:11 PM
Anthony Rud
10-03-2020 06:06 PM
tite_tite
09-25-2015 10:21 PM
