Help Clutch fluid leak
Clutch fluid leak
I have an 08 G37 6MT and every morning when I drive my car I have to pump the clutch pedal a couple of times to get pressure to drive the car. I also found out that after a couple of days I have to refill the clutch fluid a little bit so obviously there's a leak somewhere. The thing is when I look under the dash for any clutch master cylinder leaks I can't seem to see anything leaking unless I'm missing something. There aren't any leaks from under the car either. I have a Z1 CMAK kit so perhaps there could be an issue with that? Wondering if anyone has any insight on this issue.
I just had to replace my slave cylinder a few weeks ago. Its inside the transmission, I went ahead and replaced the clutch and flywheel. You can try looking for a leak in the piping under the hood, against the firewall, also look on the inside of the firewall behind the clutch pedal, but its likely in the transmission.
PNW_IPL (01-28-2020)
fwiffo
01-01-2018 02:14 PM
Jonesmeister11
22
12-23-2015 02:30 AM
