Can someone help me with my 2010 G37 Coupe
My 2010 G37 coupe recently has been giving me the VDC off light, ABS light, and the slip light at the same time. The lights will come on when I am driving and after the car has been turned off it will not start again. It will not even crank over. I realized that it might be the brake light switch so I fiddled with it and it got my car running again. So i ordered a new on and installed it. Car ran great for 4 or 5 days. Then all of the sudden the lights came on again this morning before heading to class so I turned it off and tried to start it up again and it wouldn't. It is back to the same place it was before replacing the brake light switch. When it is refusing to start it is not registering my break press and the tail lights are not working either. however my steering wheel is not stuck in lock and my gearshift can go into other gears. Is it possible that it is just some fuses are out and need replacing? Any help would be much appreciated.
Krieger88
03-29-2016 08:18 PM
