Rpm boggs to 2000rpm
Update: cleaned the throttle bodies, they were pretty dirty. I can now start the car every time.
The car is now idling rough, and dies when I push the accelerator to the floor quickly. If I slowly push the accelerator down, the RPMs advance just fine. It does seam that the car is misfiring, but I am not getting any fault codes. like a P0300 or anything, I have tried doing the ECU reset several times.
Just an Fyi, i had zero codes with my gallery gasket leaking. I noticed car acting funny and felt off and it got worse over time so i started testing and trying to figure out what it was. Checked oil pressure, and yup was below specs by a good bit. She was hesitating a good bit too. More over time
G-MENTED
12-04-2017 07:35 PM
G37beijing
11-06-2010 09:04 AM
