Clutch (not pilot bearing) noise
hi ive install a csc delete kit zperformance,southbend dxd stage 3 drag clutch with excedy lightweight flywheel 15lbs instead of 35lbs
when in neutral with no clutch pedal press the bearing making a lot of noise pretty sure ive seen some g37 stock having this problem its just louder now and stop as soon as i press the clutch pedal anyway to make this noise go away or less loud thx !!
Meh, I've seen worse from other users...
I recall these cars have a considerable amount of clutch chatter when you upgrade the flywheel. I'm a 7AT driver, but my friend parked his mustang this year. I drove it a few times, and the clutch would always make a very slight squeaking noise when you just start to depress the pedal. That was his throwout bearing on its way out.
I'd recommend posting a video if you think it's worth it, noise can mean anything from a squeak to a rattle to a banging noise.
OP, your total lack of punctuation makes my head hurt when reading your post.
As for deleting your post because it's actually the clutch making the noise, I'm going to leave it because it will help others who might be thinking the same thing you did when you made your post. I will change the thread title to reflect the new info, though.
Its not the clutch making noise it is the transmission making noise as you went to a Solid flywheel instead of the factory dual mass flywheel, When you do this it causes the gears to
"chatter" in the transmission at idle if you let your foot off the clutch. It is normal with a solid flywheel unless you get a clutch with a "quiet" type option like Southbend or ZSpeed offers with their kits.
However the noise does not pose any issues with the trans and does not hurt anything.
You can get this noise even with the OEM flywheel if the flywheel dual mass section is worn out which happens quite often.
unknown2k1
03-04-2021 09:13 AM
Gavin17
10-26-2018 01:25 AM
hobbs
47
02-18-2014 01:30 PM
37drift
10-18-2011 01:38 PM
