Gallery Gasket
Old 10-08-2019, 08:34 PM
antirice
antirice's Avatar
Sorry to hear. Was the check engine light on?
For a 2010 that's pretty low mileage.
Old 10-08-2019, 11:10 PM
TheDevilsG
TheDevilsG's Avatar
No check engine light. No codes. Slowly losing more and more power at low rpm. Checked oil pressure and got those readings.
Old 11-04-2019, 06:35 PM
Ben Green
Ben Green's Avatar
Angry Help VQ37 Galley Gasket Canada
Hey Guys here with my G37s,
I have to replace the Rear Timing Cover Oil Gallery Gasket on my VQ37 but running into issues with buying the parts. I live in CANADA and the few places I normally buy parts (Autopartsway, Wrenchmonkey, Napa, Ebay, Amazon) does not sell these parts.
The company is the USA called https://www.z1motorsports.com/ have every thing I need (newer ungraded metal seals and even sell them in sets) but cant find anything like that where I live.
anyone able to help me with this or had the same issue
rather not go to Infiniti / Nissan dealer $$$
Thanks
Old 11-04-2019, 06:43 PM
PNW_IPL
PNW_IPL's Avatar
Only one company makes an aftermarket gallery gaskets. EPS.
Z1motorsports is a reseller of dealer items.
The chances of a normal auto parts store having them is zero.
Conceptzperformance sells them as well.
So order online in USA or walk into a dealer. Nissan or Infiniti.
Nissan is usually cheaper. Also do the water pump while there. If it goes bad you'll have to pull the timing cover to get to it. Might as well do all once. Also inspect guides and chain
Ben Green (11-04-2019)
Old 01-15-2020, 06:04 PM
TheDevilsG
TheDevilsG's Avatar
Update
Just an update Now months after the work has been done: The car is running like a dream. All the power is back, She drives amazing. I couldn't be happier.
The shop did great work, amazing guys really. If anyone in toronto needs a shop to get the gallery gasket done please feel free to message me.
I had a gauge added to keep tabs on oil pressure and its been solid.
Aem oil pressure gauge wanted it discreet so in the glovebox is where she lies.
All tidy because im ocd about wiring and such. I actually dig how it looks in there lol ( a 2 dollar bracket via amazon, and some plastic tubing for a few bucks... done and done)
The following 2 users liked this post by TheDevilsG:
Bobbybanterz (08-24-2020), PNW_IPL (01-15-2020)
Old 01-15-2020, 06:10 PM
Received 4,711 Likes on 3,519 Posts
That's a good feeling, that your car is running right.
So parts, labor, water pump, etc., how did it all add up?
Old 01-15-2020, 06:28 PM
TheDevilsG
TheDevilsG's Avatar
I paid around 2100 Canadian for the parts and work to get her back to healthy status. Cant complain at all considering how labour intensive that job is.
Old 01-15-2020, 06:30 PM
TheDevilsG
TheDevilsG's Avatar
I also recently treated myself to a stillen oil cooler to take advantage of a black Friday sale at stillen 😁.
Old 01-15-2020, 06:37 PM
Thanks. That seems about right.
Old 06-17-2020, 02:41 PM
G37xRoss
G37xRoss's Avatar
what did you order so you could get it to fit perfectly in your glove box? I want the same set up it looks very clean. Any links you could provide?
Old 06-17-2020, 04:23 PM
TheDevilsG
TheDevilsG's Avatar
Sure no problem man. Here you go! (Link wasn't working but here is a pic)
Just use two small screws (i think it came with them) to mount it to the bottom of your glove box. I did place two nuts so the screws wouldn't go too deep into the glove box)
Get some black wire loom to feed the two wires of your gauge into it. I mounted pretty far left and tilted towards me so it doesn't take up much space in my glovebox and its easy to see from drivers seat.
cut the wire loom there because higher and it will get caught when closing the glovebox. You won't see that from drivers seat or passenger seat, Don't worry ( i opened glovebox really wide to take a pic for you) . Glovebox opens fine no rubbing or clipping or anything.
Old 06-17-2020, 05:23 PM
G37xRoss
G37xRoss's Avatar
hey man thanks a million! Do you know the gauge of the wire in case I need to extend it? 16 or 18?
Old 06-17-2020, 06:46 PM
TheDevilsG
TheDevilsG's Avatar
I don't remember and im not near the car now, i want to say 18 but i am guessing man lol
Old 06-17-2020, 09:13 PM
  #29
GofToronto
GofToronto's Avatar
hey @TheDevilsG could you please provide the name and contact info of the shop you have mentioned. I am in Toronto/ Missisauga. My CSC just died and while the car is down might as well get the gallery gas-kit and water pump done as well. Would appreciate if we could connect directly.
Old 06-17-2020, 09:53 PM
  #30
TheDevilsG
TheDevilsG's Avatar
Info Sent via message. Goodluck man.
Quick Reply: Gallery Gasket
