2008 Infiniti G37S lagging
Old 09-26-2019 | 06:58 PM
J.cantor's Avatar
J.cantor
I've done a search, failed to find my exact problem. As the title shows, I have a 2008 Infiniti G37s 6speed. After driving, when the problem starts to happen, I will stop at a light for example, notice my RPMs higher than normal at an idle, at like 750-800 at that point I will take off, but pushing the accelerator hard will lag hard, like very sluggish, I press it lighter and it is fine, shift to second and push a little harder on the accelerator and again it is bogging down as I let up a little it's smoother. If I shut the car off, and then restart it...then drive it everything is normal again. The car has about 134K on it.
Old 09-26-2019 | 08:30 PM
jpowersjr2's Avatar
jpowersjr2
You likely will not find your exact problem because there are dozens of things that could be contributing to the symptoms you are experiencing. Start simple, diagnose any CELs if you have any first. Run SeaFoam through crankcase, brake booster, and gas. After that, put in fresh fluids (engine oil, trans, diff) and new OEM Denso 3457 spark plugs (105k is the service interval). Clean throttle bodies and perform throttle body relearn procedure (search on here). Only run 93 octane (or 91 if that isn't an option). Don't cheap out on the fluids either. A lot of members here (including myself) go with Redline or Motul for trans/diff/clutch.
All of this is fairly cheap and you can perform the labor yourself. Even if it doesn't fix it, you still have knocked all of this out and will be good on maintenance for awhile.
Old 09-26-2019 | 08:35 PM
J.cantor's Avatar
J.cantor
I've changed all my fluids, changed my plugs only a year ago. I am stuck with 91 octane here in Commiefornia, cleaned my throttle bodies less than a year ago, and have done the relearn multiple times. I've even flushed my clutch fluid.
Old 09-27-2019 | 01:26 AM
slartibartfast's Avatar
slartibartfast
Your problem is not uncommon. Searching your exact symptons is what caused you not to find anything. You sometimes have throw a wide net.
Old 09-27-2019 | 01:07 PM
J.cantor's Avatar
J.cantor
Will do. Thank you
Old 09-28-2019 | 11:41 AM
Hashim Black's Avatar
Hashim Black
Even though mine is an automatic, im having the same problem
Im having the same problem
Nashville G
09-01-2015 12:06 PM
infinitipro
06-10-2015 05:15 AM
g37sgrewal
04-03-2012 12:34 PM
Geaux G37
21
01-21-2008 11:05 PM
Quick Reply: 2008 Infiniti G37S lagging
