Is there a DIY for Replacing Pulleys?
Has anyone replaced their whole pulleys system including the tensioner? My pulleys and belts are on their way out soon so I was wanting to know if there’s a DIY anywhere? I couldn’t find any from Google and the Myg37 search bar, only serpentine belt changes. And is there anything else I should know? I heard that there are special pulley tools to check if you don’t tighten it too much so the belt won’t snap.
Replacing the tensioner (and pulley's) is relatively easy. One bolt for each pulley. The only "special tool" you would need, unless you already have one, is a good quality torque wrench. Very important that you DO NOT OVERTIGHTEN the bolts. The entire procedure as outlined in the FSM (no mention of a "special tool"):
I circled the bolt torque specifications in blue and are measured in ft.-lbs.
Hope this helps!
Hope this helps!
The following 2 users liked this post by ILM-NC G37S:
Baadnewsburr (09-27-2019),
Joyryde (09-27-2019)
Hope this helps!
Hope this helps!
You would only need a "special tool" (something to hold the pulley still) in cases where the bolt is secured to the shaft itself (which turns). If you think about it, the crank pulley, AC compressor, alternator, P/S pump- just about every belt driven accessory- has the bolt (nut in some cases) directly attached to the shaft.
In the case of the idler pulleys the mounting bolts are attached through the pulley bearing directly to the block. Torque values must be followed exactly here: too loose and the pulley bearing can work the bolt free (causing the pulley to fall off) while too tight and you risk cracking the timing chain case. The bolt for the tensioner passes through the spring housing and is not subject to any rotational force.
Maybe this stock image will help you visualize:
Hope this helps...
Hope this helps...
Hope this helps...
Hope this helps...
I replaced all my pulleys when I replaced the tensioner. As mentioned by others, no special tool is required. Actually it is a very easy job. I used my Gearwrench 3680 Racheting Serpentine Belt tool which made it easy to remove the tensioner. The pass-through sockets of the Serpentine Belt tool can also be used to remove the shock mount on our struts so not a bad investment if you do maintenance and repairs on your own vehicle.
Here is a pic of the pulleys and the tensioner that I replaced on my coupe at 77,000 miles/10 years. The pulley bolts are attached to the pulley.
Good luck!
UCLAg37
Good luck!
UCLAg37
Baadnewsburr (09-30-2019)
I need to replace the exact same pulleys - well at least for me: number 4 and 5 idler pulleys (from diagram above) and tensioner. Any chance you can list where you purchased them or the part numbers? I found what I think i need from rock auto but I always like make sure.
Additionally, when I took off the serpentine belt - i spun all the pulleys and noticed that my alternator pulley had a fair amount of resistance to it. It spins but just not "freely." Doesn't make any noise and there is no play but I am thinking that it might be starting to seize? First time changing the belt @ 100k miles so I tried to be careful and thorough about everything.
Also if you don't mind listing the torque specs it would help but i can find that information if you don't remember
-Thanks in advance
-Thanks in advance
Str8Gtime,
I usually buy most of my parts from Discountinfinitiparts.com. A link to the parts is below. I believe you need to buy two of the ribbed idler pulleys (11925-JK20D) and one of the smooth surface idler pulleys (11925-EY00A) if you want to change all of them. The tensioner is 11955-1EA9D.
To confirm the parts numbers, go to the Discountinfinitiparts.com and type in your vin number and click on "maintenance and lubrication." Then click on the :"belts and pulleys" link. You need to check your own vehicle because I don't know if any parts numbers have changed from my 2008 model year.
https://www.discountinfinitiparts.co...ts-and-pulleys
After you get the parts numbers, you might also compare prices on dealers who sell on Ebay. I bought my pulleys,belt and tensioner 4 years ago and I noticed the prices have increased about 20-30 percent.
As for torque specs, see the second post above. ILM-NC G37S was kind to circle the torque specs in blue.
Good luck!
UCLAg37
Good luck!
UCLAg37
BOLT size
Hey guys so my idler pulley completely came off on the freeway when I was driving from Utah to Arizona, luckily I made it to Phoenix but the entire pulley and bolt came off. Anyone know the bolt size I’ll need?
Kev@US-Autotech
Supporting Vendors
46
10-13-2010 03:14 PM
