Spark plug question
Old 09-23-2019 | 09:41 PM
Illmoja's Avatar
Illmoja
Spark plug question
Good day all.
Thinking of installing new spark plugs on my 2008 g37s and I am planning to buy them from rockauto. However I am not sure which NGK spark plugs to buy. Im somewhat confused because there are two NGK entry:
1. NGK 90174 gap 0.044" laser iridium (#1305) 15.56 cad/piece
2. NGK 1305 gap 0.044" laser iridium 30.26 cad/piece.
Am I missing something here? Of course I would opt buying the cheaper one. Its just I dont want to buy the wrong/incompatible parts. Thank you.
Old 09-23-2019 | 09:50 PM
saywat?'s Avatar
saywat?
yea ur missing the correct brand. open the owners manual and do some reading
The following 2 users liked this post by saywat?:
Eddie Ex (05-17-2020), telcoman (09-24-2019)
Old 09-23-2019 | 09:55 PM
Illmoja's Avatar
Illmoja
Outta here troll.
Old 09-23-2019 | 11:00 PM
jpowersjr2's Avatar
jpowersjr2
Not a troll. Do your research. OEM or bust for spark plugs, Denso 3457.
Old 09-23-2019 | 11:46 PM
Illmoja's Avatar
Illmoja
Sorry just had to reread my question lol. Im not asking oem vs ngk. I was just wondering if those two spark plugs listed above are the same or am I missing something here.
Old 09-23-2019 | 11:52 PM
jpowersjr2's Avatar
jpowersjr2
Not sure but don't buy them if they are for your G.
Old 09-24-2019 | 01:45 AM
Illmoja's Avatar
Illmoja
No love for NGK here I guess. Thanks yall for your input
Old 09-24-2019 | 01:49 AM
Surfnazi's Avatar
Surfnazi
Denso iridium plugs are like 15 a piece
Old 09-24-2019 | 02:44 AM
slartibartfast's Avatar
slartibartfast
The VQ37 seems rather sensitive to spark plugs. If you do some searching here, you'll see that. Which is to say, don't bother trying to differentiate the NGKs as neither will perform satisfactorily.
Old 09-24-2019 | 08:16 AM
RMB5190's Avatar
RMB5190
Which is surprising since NGKs have a pretty good reputation. For whatever reason, Denso plugs are the only ones that play nice with our car.
OP, I had a similar inquiry when I changed mine out. I've ran NGKs in my past three cars and never had an issue. After some reading on here, a lot of owners would throw codes, misfires and a laundry list of other issues.
I installed the Denso plugs 20k+ miles ago and have not had a single issue. Unless you're running a boosted application and require colder plugs, the OEM plugs are the way to go.
Old 09-24-2019 | 10:20 AM
Baadnewsburr's Avatar
Baadnewsburr
My 0.02, I have the VQ35HR, I have used 2 sets of NGK lazer iridium's with no problems about 100k kms on each set ...that being said Denso are a safer bet as they are OEM.
To answer your question, the tw ospark plugs you are comparing are the same. They are both the NGK #1305 Lazer Iridium spark plug. the difference is that the second one is the per-unit price in a 4 pack. For some reason the per unit price is cheaper when you buy them separately...this was the case when I bought them from rock auto as well...i.e you can't buy 6 of the the 2nd option, you'd have to buy one four pack and two of the others anyways...Just order 6 of the individual ones
Old 12-19-2019 | 08:27 PM
seayky's Avatar
seayky
I was searching for OEM spark plugs (Denso 3457) but it looks like they have been discontinued or in shortage unless getting them at Infiniti/Nissan dealers. There are plenty of "OEM" plugs on Ebay and around $30 for 6 but I hesitate to get them there as they are super cheap and does not seem right. There is one selling for $15/each but I am still not sure if they are the real OEM plugs.
The other plug, like OP says is the NGK DF8H-11B (90174). I don't know if these would really cause issues. Anyone tried?
Another question: Where do you get the spark plug socket (14mm 6 point, magnetic)? I found one " BikeMaster 14mm Magnetic Spark Plug Socket" but it is not a thin wall type. Is 9/16 with 12 points OK to use?
Thanks!
Old 12-20-2019 | 07:11 PM
jpowersjr2's Avatar
jpowersjr2
Only use OEM Denso 3457 FXE24HR11. Find a coupon code and buy the right part. Don't cheap out on crappy plugs, you'll regret it.
https://shop.advanceautoparts.com/p/...rm=spark+plugs
I didn't have to use a thin walled socket. Any auto parts store should have the socket you need.
Old 12-27-2019 | 01:38 PM
Surfnazi's Avatar
Surfnazi
Oreilys has a 25 off 100 order coupon code with free shipping, you can get 6 denso for under 80 bucks
Old 12-28-2019 | 03:22 AM
seayky's Avatar
seayky
Denso plugs are out of stock almost everywhere. Autozone, O'Reilly, Napa all out. It might be discontinued! I ordered mine at https://conceptzperformance.com/
Quick Reply: Spark plug question
